Thread: any reason NOT to raise heater 6 inches?
    I am replacing the heat exchanger and would like to re-plumb it and raise it up 6 inches to be able to have some clearance underneath. Will this cause a problem with my pump??
    Cleveland, Ohio
    IG 36,000 gallons. Vinyl Liner, Hayward ProGrid 3620 DE Filter, Hayward Super Pump, Hayward Gas Heater
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: any reason NOT to raise heater 6 inches?
    Shouldn't matter. What are you going to put it on? Why do you need clearance underneath? It just seems like a good place for animals and spiders to hide...
    Right now when it rains water just sits underneath it and cant drain properly. I would like to raise it a bit so I can clean properly under it and it will drain when it rains. The way the pool pad and my patio meet right there is just not ideal and it kind of causes a bit of a puddle to form right under the heater. Im concerned it will rot. I figured since I am re-plumbing it right now because I had to by pass it while I waited for the heat exchanger to come in and now i have to re-plumb it back to the heater I would raise it a few inches. thanks!
    Cleveland, Ohio
