Thread: overlap install jitters
    Jul 2008
    Bucyrus, Ohio
    108
    we are preparing to install a new liner tomorrow mornin on our pool. It 15ft overlap. problem 1...cant get skimmer box off wall, so how do I use a shop vac to suck the liner to the wall? problem 2...if you have to be in the pool to smooth the liner out on the bottom...how do you get our without using the ladder cause if we put ladder in it will mess up the sand before its set??? ANY and ALL advice is great appreciated!!!!!!!!!!!!!!!!!
    Overwhelmed
    Pool size: 15' X 48" AG vinyl liner, 5300 gallons, Hayward S166T filter and 1hp pump
    Aug 2011
    Virginia Beach
    295
    Re: overlap install jitters
    Put a board under the ladder feet to spread out the weight?
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/½ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
    22,553
    If you use the shop vac you don't have to be in the pool to stretch the liner out. It will stretch tight under the vacuum. We use a soft broom to manipulate the liner as it's going in.
    Just pull a liner clip off the wall in one section and stick the vac hose in there. Or just stick the vac hose in the top of the skimmer out the front and down the wall. OR just use plastic or boards to seal off the skimmer around the vac hose and it'll suck the liner to the wall. You may have to provide some relief around the face of the skimmer so it won't just suck the liner into the face of the skimmer.
