Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: bad match - should I replace the filter or the pump?
    Howdy,
    So, our new to us pool came with a A.D. Smith Centurian 2.2hp pump and a Pentair FNS DE filter (48sf). Apparently this is a bad combo as the pump is way too powerful for this filter. My pool is about 12k-15k gallons. Two pool guys told me that I either need to upgrade the filter or get a smaller pump. Both are fairly new. One pool guy told me that the manifold is cracked, he showed a black part (to where grids attach) inside the filter with a good size crack/whole in it.
    I assume one of the grids is now cracked, I added DE via skimmer and some of it came out via return lines.
    A good pump is almost the same price as a filter. I assume that I have the cheapest pump money can buy and should not expect much efficiency out of it. Would love to get an energy efficient pump to keep the cost down. Some people claim a $40 per month difference in electric bill with the new Pentair IntellFlow pumps.
    Open to suggestions.
    FYI - summary of my week:
    1. cooktop's glass seal breaks along the perimeter of the glass
    2. Dishwasher dies
    3. Pool's timer dies
    Thanks God previous owners purchased a home insurance.
    ~14,000K avg 5.5ft deep kidney shaped pool + Waterfall.
    Challenger 2.2hp pump, Pentair 48sf DE filter.
    Ft Lauderdale, Florida
    1,455
    Re: bad match - should I replace the filter or the pump?
    For a 12 - 15K pool, you certainly do not need 2.2 hp, unless you have water features (waterfalls, deck jets, etc) or a spa with hydrotherapy jets. Price out the manifold for your filter and get a smaller pump.
    Think of the calculations this way:
    If your pump is 230 volts, drawing 11.2 amps (per http://www.poolcenter.com/pumps_CHALLENGER_POOLSTOR.htm),
    =2576 watts (P=IxV) x 24 hrs (worst case) = 61824 watts/day = 61.82kw/day x $0.11/kw (you can change this to your actual electrical cost) = $6.80/day x 30 days = $204/month...but that's running your pump 24/7!
    SO, assuming an 8 hr run time ==>$68/month.
    However, if you reduce your pump to a 3/4 hp pump, (230V @ 5.4A), using the same calculations ==> $33/month
    The Intelliflo can possibly save a bit more, but the initial cost may offset the savings.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Just to add to what Poolsean has said, your filter size is fine for that size pool, but the pump is too big. Was it chosen because of the waterfall? You might also want to consider a 2 speed pump, and run on high if you need a bit more boost when the waterfall runs, but run on low (and a lot less power consumption) the rest of the time.
    22,550
    Also take into account your electric rates. Anything above 25¢ per kwh and a variable speed pump begins to make sense. Below that a 2-speed is usually a better investment.
    Yes I do have a waterfall. I'm paying about 8 cents for electricity.
    What pump would you recommend?
    Thanks for your input BTW.
    22,550
    Can you give us the model number on the pump?
    And the catalog number on the motor?
    I'd just change the motor on the pump to a 2-speed model given that you have a waterfall and probably need the flow of the high hp pump.
    Hey,
    I just got back from a trip. Attached are model # from the pump. It seems the motor is Centurion yet the part is a challanger.
    front portion
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Most challenger pumps have a centurion motors. The pump CHII-N1-2A. That is from their high pressure line. They show no 2 speeds for that line, but as Bama mentioned I would guess you could go to a 2 speed motor. Are you running 110 volts or 230 volts?
    Quote Originally Posted by linen
    No idea. How can I find out? So just swap the motor? keep the pump the same? How can I tell if the new motor will work with my pump?
    22,550
    That motor is 230 volt only. So that's easy!
    Yeah, just change the motor. You need a B985 or equal. And get a shaft seal too.
    How do I identify what type of frame size/type I need? http://www.poolsupplyworld.com/poolsupp ... s/B985.htm something like that? Any other options?
    mas985's Avatar
    Pleasanton, CA
    11,737
    A.O. Smith makes a new line of two speed motors (E-Plus) which has higher efficiency at both low and high speeds. The B2983 should be the correct motor although it is labeled as a 1 1/2 HP full rated motor. Your current motor is a 2 HP up rated which is the same size (THP).
    Mark
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    doh and right on the label too
    Quote Originally Posted by VKJK
    Looks like the one Mas mentioned is cheaper than the one you pointed too. Here it is: http://www.poolsupplyworld.com/pools...ucts/B2983.htm
    mas985's Avatar
    Pleasanton, CA
    11,737
    B2983 is a 2.2 THP motor which is the correct size for your current pump and it is higher efficiency.
    Mark
    Quote Originally Posted by mas985
    right and I can run it a lower speed and higher when using the waterfall.
    Is there anything else I need to know or do to replace the motor? I'm going to try to do this myself.
    May 2009
    Youngsville NC
    395
    Get a pump seal kit while you're at it.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
  20. Back To Top    #20
    Hello everyone, I have some sort of a similar issue with my pool. I live in Puerto Rico and the energy cost is variable but is between $0.19 to $0.22 Kwh. I have an inground pool (1 year old) and I also have a Pentair 48SF DE Filter. I currently have a Waterway Single Speed 2.5HP pump (SVL56S-125), the pool installer suggested this setting since I have a Gas heater, solar heater system 2" piping and 3 water features (Waterfall, Deck jets and hydrotherapy jets in the pool) I also have a salt system installed. I have a 12 x 24 inground pool and it is between 11000 to 13000 gallons.
    With energy cost so high I am running the pump for 4 hours a day. I did the math since the Waterway pump is 11.5 Amps and with the 4 hours of run time it is consuming approximately 296 kw on a monthly base. I am thinking on replacing this pump with a more efficient one, so far my choices are either an intelliflo or the ecopump... I am concerned with the electronics on the intelliflo since all my pool equipment is exposed to the elements... On the other hand the ecopump gives a total 5yr warranty witch I think is not that bad...
    So My question is due to the fact of the water features that I have, pipe size, solar heater and filter size, I am not sure if I should downsize to something smaller than 2.5HP or not...
    Does anyone knows if the A.O. Smith makes a new line of two speed motors (E-Plus) can be hooked to a waterway pump?
    I am just looking for ways on lowering my energy bill, since the costs of electricity here are way too much and we all know that they will keep rising. But I want to make a smart decision, due to the fact that either the pump I chose is going to be $800+...
