Results 1 to 8 of 8
Thread: Pool Test Kits
    Pool Test Kits
    I have a Taylor K-2005 test kit so am not familiar with the FAS-DPD titrating reagent - can someone explain to me what this test actually does and can I buy the reagent R-0871 and use it with my current Taylor kit?
    Above ground 17,000 gallon vinyl lined
    DE filter
    Re: Pool Test Kits
    The FAS-DPD chlorine test measures FC and CC levels up to 50 in uniform steps of 0.5. To use it you need to get R-0870 and R-0871. I suggest you get a complete FAS-DPD add on kit, instead of just the two reagents, which is easy to find on the Internet. That will give you the instructions, a tiny spoon you need, as well as a spare test vial.
    Re: Pool Test Kits
    Thanks for the info - I will check on the internet. Appreciate the help.
    DE filter
    Feb 2012
    Winston Salem NC
    161
    Re: Pool Test Kits
    This is my first recomendation for the TF-100.
    It comes with easy to understand instructions, and it is also an easy way to drive the golf cart out to the pool (for me) and knock back a few cold IPA's while performing tests. THe best part is that you know the numbers are meaningful and you can share them here and get immediate feedback!
    18x36 IG Vinyl. ~29k Gallons.
    Pentair CCP420 Cartridge Filter
    Pentair Inteli-flow VS Pump
    Hayward Goldline SWG
    Tigershark QC Robot
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pool Test Kits
    For my pool it was a Kawasaki Mule that ended up in the shallow end, which was particularly impressive not only because the pool is indoors, but because the front bumper cleared the french door frame by less than an inch.
    Getting it out though did not involve a TF-100 in any way.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: Pool Test Kits
    This is all you need to upgrade http://tftestkits.net/FAS-DPD-Chlorine- ... t-p47.html
    You have a different chlorine test in your kit vs the TF100; but once you have the FAS-DPD test you won't be using it much anyway, so who cares?
    Re: Pool Test Kits
    Thanks for the help - just ordered the FAS-DPD from tftestkits - good suggestion. Should be good to go from here.
    DE filter
    30,395
    Re: Pool Test Kits
    Music to my capitalist ears!! It'll ship today.
