Results 1 to 7 of 7
Thread: How to shock an above ground pool
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    I have a 24 by 52' pool and shocking for the first time. I'm using powdered bags and was wondering how to shock it. Thank you.
    Above Ground 30' by 54" 22,600
    Hayward S244T Sand Filter w/ 1.5HP Dual Speed Hayward Powerflo Matrix Pump
    TF100 Test Kit
    BBB ALL the way!
    Questions about pool care? Visit Pool School
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,649
    Re: How to shock an above ground pool
    Step 1: Return "powdered bags" for refund
    Step 2: Read pool school on shocking your pool
    Step 3: Post us some test numbers and we'll be glad to help.
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Everything you need to know is in Pool School - How To Shock Your Pool
    Woops...Woody beat me to it. But there's a link.
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    dittos on what woody said.
    Shocking your pool is not a product within a bag, but instead a process. Read pool school and with enough time and persistence you will get it done no problem. I just had to undergo this recently when I had to fight off some algae. Listen to these guys they are very helpful and good luck!
    10'(round) x 30"(deep) Intex Easy Set AG Pool 1,500 gal | Intex 56673EG 14-Inch Krystal Clear Sand Filter Pump 0.5 horse power pump with 1,600 gph (6.0m3/hr) flow
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    Well my numbers straight from the hose with no chemicals added are all 0, but PH which is 6.5. So that is what is in the pool right now.
    TF100 Test Kit
    BBB ALL the way!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    How does your water look? Why are you do you want to shock?
    Quote Originally Posted by Blake1989
    That is very unlikely unless you tested for very little else. We need to know FC, ph, TA, CH, and CYA levels. See: http://www.troublefreepool.com/what-...ns-t10341.html
    Is your water from the city or from a well?
    How are you testing?
    Take a look at the link in my sig on test kits. Your pool experience will go much better with the appropriate test kit.
