Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: My dog ate my pool
    My dog ate my pool
    Any suggestions?
    -Mark
    No pool right now: hoping for a gunite pool in the near future
    Previous pool (poles rusted out due to salt water):
    6300 gallon Intex above-ground pool
    2650 GPH Intex 100lb sand filter
    CS8110 Salt-water Generator
    Butterfly's Avatar
    South Carolina
    10,045
    Re: My dog ate my pool
    How is the dog now?
    You're done SLAMing when:
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I have read on here somewhere someone using large tie down straps to replace the strap. The rope can be replaced with rope.
    Feb 2012
    Phoenix, AZ
    728
    Did the dog try to frame someone by putting that sword on the ground!?
    EDIT: is-my-liner-ruined-t41186.html this is the post that I read about the same thing happening. As you will see, Zea mentions another (even OLDER) post..I will try to find THAT one if I can...
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    Use the ratcheting tie down straps and go around the pool. I used them to replace the pos rope on the bottom to keep the legs from splaying all over the place.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Well, as you can see, the poles are on concrete blocks. If I screwed the poles down so they don't pop out, and took OUT the rope & the big blue thing, would that work? Does the liner need that blue thing, or is it (and the rope) only there to keep the legs from popping out?
    The dog is fine. She's a 5mo old yellow lab with too much energy. So I played fetch with her until she wouldn't get the ball any more. She's collapsed on the floor now panting...
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    I'm sure they are there for some form of structural integrity. I wouldn't want to chance not having at least one of them in place just for piece of mind
    docchop1's Avatar
    Apr 2011
    Southern Indiana
    61
    Tie one end of the big blue band in a knot. Tie the other end of the big blue band in a knot. Tie a short rope to the first big blue band knot. Take up slack and tie the rope to the other big blue band knot. Repeat on bottom rope.
    Intex 15x48, Intex Saltwater Chlorine Generator, Intex 14" Sand Filter, TF-100 unicorn eating spaghetti while riding a unicycle on a high wire during a storm edition test kit,
    http://tftestkits.net
    May 2012
    NW PA, halfway between Pittsburgh and Erie in the PA snowbelt
    159
    Thread title is misleading. That's not a "dog ate my pool" photo. That's just a "dog mildly chewed my pool" photo.
    My dog ate our pool. I literally would have needed a 5 foot patch to patch the hole. Lucky for us it was only a $99 8 footer. It was during winter when the pool was still up, but drained.
    Yes, ours was also a less-than-year old yellow Lab as well. They can be buggers. Killed 2 apple trees (completely stripped every inch of bark off both from about 6 feet height to the ground,) chewed a hole in the breezeway paneling and literally halfway through one of the wall studs behind that paneling, a 5 foot hole in the Intex pool, countless tears from the girls at toddler age when all they would find of their stuffed animals was an eye, or half a nose, countless shoes, etc, etc.
    Mike
    22' round Intex UltraFrame pool, Intex 633T 2500gph paper cartridge filter/pump
    with broken Intex SWG, using bleach this year
    TF-100 test kit
    Casey's Avatar
    SW PA
    10,438
    OMG! I feel your pain.... (or in my case) rage. I have a soon to be 1 year old German Rottweiler (rottenweiler as I like to call her) who ripped the siding off of our house just last week in a single game of tug of war. She won. I was so mad!
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Big Lots and Dollar General almost always have bags of 5 or more chew toys for $2-$5.
    Granted, they last about 30 minutes, but at that price you can afford to keep enough around to keep even 5 monsters entertained.
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
    I can't say a dog ate mine, but I keep getting squirrel attacks. just found one last Thursday floating in my pool. second one in 3 years. this time it chewed the line to my pool slide after I had just checked a couple days earlier.
    30' Vogue
    21200 Gallons
    1 1/2hp Hayward
    w/Zeobest
    "When it ain't green we be swimm'n!"
    Apr 2011
    Lynchburg VA
    393
    Quote Originally Posted by docchop1
    I like parts of this solution but I would tie big ole knots in the banding that is left and use a ratchet scrap to span the gap.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Apr 2011
    Lynchburg VA
    393
    Meet Sam, he eats cars!
    Pool School
    Pool Calculator
    Test Kits
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    574
    Quote Originally Posted by BadOleRoss
    Casey's Avatar
    SW PA
    10,438
    OMG! SAM!
    Mar 2011
    Grand Rapids, Michigan
    279
    Sam is one handsome dude! And Casey--I too, had Rottenweillers. Tucker, my first one ate my walls down to the studs when he was a youngster. When he was just under a year old I got another and he picked up where Tuck left off. After $1500 worth of repairs and the "boys" maturing some everything looked brand new again.
    17,500 gal. ABG Doughboy Pool
    1/2 HP Pump/150 sq.ft. Cartridge Filter
    TF100 Test Kit And Speedstir
    Casey's Avatar
    SW PA
    10,438
    Debbie, Boo is my second and I never had this rotten-ness with my first male rotty. She will be a year old on June 15th and she is so lucky I think she is cute!
    I fixed it. The blue plastic band I rotated around so the gap was at the back (out of sight). I then took docchop1's advice and tied the frayed ends in a knot, and used a strap to pull the ends tight. Along the bottom, I pulled out the rope & replaced with 3/16" plastic-coated steel cable. I don't think she'll get through that (I hope).
  20. Back To Top    #20
    Pointyhead's Avatar
    May 2012
    Central Georgia
    113
    I used to have labs. I quickly found out that they are part goat, part gopher. They will eat anything and dig holes to China. I've lost the wheels to my gas grill, 100 ft of extension cord, and a 50 ft garden hose to my dog.
    10 year old 18x32 inground, vinyl liner 1 year old, 25,000 gallon Grecian, Hayward ST244 Sand Filter, 1hp Hayward pump, Diving board, Side Steps, Koolcrete decking located in middle [s:37hekvij]earth[/s:37hekvij] Georgia.
