Results 1 to 14 of 14
Thread: need help opening the pool! water is cloudy
    delete
    Aug 2010
    Dallas, TX
    4,052
    Re: need help opening the pool! water is cloudy
    Shocking is a process, not a product. Please read through the shock process in pool school.
    pool-school/shocking_your_pool
    If your pool was not maintaining FC overnight, you weren't done shocking. It is normal to lose FC during the day.
    I would not depend on normal FC to clear your pool. The SWG is only there to maintain normal FC, not for shocking. You'll need bleach for shocking.
    delete
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by pacman19777
    I see, my bad, I though that you only shock the pool once in the beginning..
    Shock is not a one-time application of chemicals. It is a process of maintaining a high chlorine level to eliminate all organics from your pool.
    Read Pool School and specifically the shocking your pool link that Robbie referenced above.
    Feb 2012
    Phoenix, AZ
    728
    so if my pool is at FC = 3 I can shock to 24 again? ex: add anothe 6L of 10% hypochlorite
    Yes, you can (and should) shock the pool properly. I am not sure if 24 if the correct FC to shock your pool, because I do not know your CYA level. Do you have your own test kit? If you post full test results, we can help get you off to the right start. Just make sure you maintain shock level FC until your pool is clear and you pass the OCLT!
    PS welcome to TFP!
    delete
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I don't remember any pool store giving CC results, it's usually only FC
    CC stands for combined chlorine and it can show up when chlorine is attacking organics (like algae) in the pool water. For you to be most effective at the shocking process you will need a good test kit. See this link: http://www.troublefreepool.com/pool-...kit_comparison
    I like the tf-100 and it has fast shipping.
    What is oclt?
    Overnight Chlorine Loss Test See: http://www.troublefreepool.com/pool-...rnight_fc_test
    delete
    delete
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Here is somethine weird that hopefully someone can explain, when i test the FC if i put one drop it goes orange, but if i put 5 drops it goes dark yellow, it this normal??
    That is not an FC test. That sounds like an OTO TC (total chlorine) test.
    Repeat your chlorine test with an FAS-DPD FC test and post your results.
    delete
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    What test kit do you have?
    delete
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    added about 6Litres of 10% hypochlorite, then this morning went to the pool store to test, and they were almost shocked how much chlorine was in my pool.
    So i get 6700 gallons for you pool assuming the actual water depth is 3.5 ft. Using poolcalculator.com i get a FC shock value of 18 ppm for 60 ppm cya. Your 6L of 10% would have raised you to about 24 ppm unless you still had some chlorine in the pool, then you would have been higher. And here is the problem, you do not want to drop below 18 ppm when shocking, so that usually means, once you get it up to your shock level, to maintain you need smaller and more often doses of chlorine to maintain the 18 FC mark (or 24 if you are using the cya/chlorine chart...either works).
    Hence the need for a test kit that can read FC above 5 ppm accurately, neither of which your current OTO TC test kit can do.
    It gets worse...to really know you have killed off all organics in your pool, you also need to know CC (combined chlorine) levels, since the presence of CC over 0.5 ppm is a sign of organics still being removed form your pool. Again, you need a FAS-DPD FC test to do this properly.
    And it gets even worse...one of the other criteria that indicates that the organics are gone is the Overnight chlorine loss test. This is typically (most effective) when FC is at shocking levels and requires a loss of less than 1 ppm overnight.
    Just my 2 cents in support of getting an appropriate test kit.
