Thread: What is this?
    May 2012
    Dallas, TX
    15
    What is this?
    For the past month I've noticed this brown film occurring in my chlorine floater. See the pic here:
    http://tinyurl.com/87rl5f3
    The pool is clear, but there is a brownish dust that accumulates on the pool bottom.
    FC 5.4
    CC 3.4
    Ph 7.6
    TA 110
    CH 320
    CYA 100
    Any ideas as to what this is?
    24k gallon inground gunite with fibertech liner
    Cartridge filter 100 sq ft
    Samantha_in_AL's Avatar
    Apr 2010
    Altoona, AL
    242
    Re: What is this?
    I'm not sure, it could be pollen. I've been getting plenty of it in my pool lately. That stuff is actually the least of your worries right now. Your CC is 3.4 and CYA is 100... that's not good. I highly recommend taking those chlorine pucks out of your pool ASAP. Every one you use is adding more CYA to your water. You need to do a partial drain anf refill to lower your CYA, then start shocking your pool.
    AG 18' X 52" Round Pacifica Pool w/ Metal Diamond Unibead Liner. Installed in March 2007.
    2.5 HP Baquapure 2 Speed Pump, 200 GPM Waterway ProClean Cartridge Filter System.
    Former Baquacil user
    Converted to BBB in Fall of 2009 - Now I have a truly trouble free pool!
    38,305
    Re: What is this?
    Looks like saw dust or maybe just dust.
    Based on your test results, you have significant CC and should be in the shock process ... which is going to be difficult with a CYA of 100 (and likely higher since that is the max on the test ... try mixing 50/50 pool and tap water and then redo the CYA test doubling the results to get a little better feel how high it really is).
    May 2012
    Dallas, TX
    15
    Re: What is this?
    Quote Originally Posted by Samantha_in_AL
    When draining, is it bad to use the water to irrigate lawn?
    38,305
    Re: What is this?
    No. Especially with the low chlorine levels you are showing.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Re: What is this?
    Just don't drain ALL the water at once. Always leave at least a couple of feet in the pool.
