Thread: Question about returns
    May 2012
    tn
    34
    I read somewhere it is best to have your returns pointing down and to the right (instead of straight ahead) to make the water move counterclockwise around the pool? It this true and if it isnt what is the best way for my returns to be facing.
    16x32, 20k gal, IG, vinyl, hayward sand filter model S244T 24in, 1.5hp
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    Re: Question about returns
    You don't want them to break the surface of the water. From top of pool, mine is facing down at 100-110 degrees to the right and circulates the long way around the pool back to the skimmer. Play with it and see what works for you.
    Feb 2012
    Phoenix, AZ
    728
    Every pool is different, but you are on the right track! Pointing them down tends to get better circulation than pointing them up. As far as direction, I don't think it matters if it is left or right (as long as the direction is consistent among all of the returns). You can float a ping pong ball or two on your pool to get an idea about the surface circulation.
    38,260
    Warning!!! Non-nerds need read no further.
    There is probably something about the Coriolis Effect here to "optimize" the direction you would want your pool water to flow. It would be opposite for those down under.
    Granted this is likely a small difference in water flow ... but the toilets do flow the opposite direction in the southern hemisphere
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    It really depends on your pool. Aiming them down is probably best for water circulation, but aiming them up makes the skimmer work better at clearing the surface. Since I have a main drain, I aim mine so the ripple the surface and move things toward the skimmer.
    This is exactly what I found. If you have a slight ripple on the surface, the skimmers works best. At first, I pointed them down and found to have a lot of dust accumulating on the surface (the pool is a waddling of 2 feets deep). Since they are a bit on the surface side, the water is crystal clear.
    And the theory of the earth rotation, I think this is why we want it counter-clockwise.
    Indoor 160K gal. tile pool, Pentair 15 Hp Epoxy coated pump, 5 Vortisand 150 gal. sand filter tanks with PLC programmed BW, Pulsar 3 tablet chlorinator, acid injection, Strantrol 5F ORP controller, titanium heaters, level control, vaccum line.
    ...and a paddle pool.
