Results 1 to 8 of 8
Thread: Never-ending pool nightmare. Buckled walls.
    I have a 33' round AGP.
    One side of it is partially backfilled/built into the ground.
    We had an absolute dead algae nightmare this spring. Long story short, we had a rainy cloudy weekend, a souped up pump from the firehouse, and 4 hydrants at the house with hoses to start refilling. We decided to drain.
    Well, hubby didn't think about and, and wouldn't you know, when the water got low, the wall started to buckle where it was backfilled due to all the rain. Not really bad, just a few areas where its dented in maybe 2-3 inches. (Bad enough though, if you ask me). Although he does say the pool is still in the bottom and top tracks, and we can see no damage to the water.
    He did dig away most of the backfill (and stopped pumping, and started filling) as soon as he noticed this was happening.
    Now. I think we can gently tap it back out. He says we can't, that the liner could tear. HE wants to leave it, and that thought scares the **** out of me, I'm afraid it can lead to problems down the road. Maybe this is the world's most wishful thinking ever, but I'm not convinced if we removed ALL of the backfill, that the water might just fix it on its own (stop laughing at me).
    Any advice for two novice pool idiots??????
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Never-ending pool nightmare. Buckled walls.
    Any uprights bent?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Well..........mine is buried 2 ft. plus or minus all the way around. Wouldn't you know it........that as soon as it was installed and filled we had a torrential downpour/monsoon. I've had a couple of inch to inch and a half "dents" going on 3 years now. Too much loose heavy dirt settled much too quickly . Hasn't been an issue if that help relieve your concerns any. And it's about a foot up the wall from the bottom.
    Quote Originally Posted by JohnT
    Any uprights bent?
    Nope! The only faults we can find are in the pool wall itself!
    Quote Originally Posted by woodyp
    Good to know! Thanks!
    SW Indiana
    9,199
    Quote Originally Posted by Basset_Hounds
    Any uprights bent?
    Is it full of water now?
    Any uprights bent?
    Yep.
    I agree with you husband that if you try to pound out the dents you will almost definitely damage the liner.
    16x32 Oval In-ground Vinyl, ~17,000 gallons, Hayward 1hp Superpump, Hayward S245T Sand Filter
    Worn out sand? sand-filter-expert-help-t30049.html
    Drain the easy way: cyanuric-acid-blues-draining-pool-t43843.html
    http://tftestkits.net/splash-page.html , pool-school/chlorine_cya_chart_shock , pool-school/shocking_your_pool
