Results 1 to 9 of 9
Thread: Filter Pressure Drop
    SPKNout4CHRIST's Avatar
    Mar 2011
    Goldsboro, NC
    210
    I noticed yesterday that my filter pressure has dropped from its usual PSI of about 15 down to 10. I made sure the skimmer baskets and the pump basket are clear and they are. I isolated each of the skimmers and the main drain to see if that made any difference and it did not. I bled the air in the filter with no change. The returns and the water in the pump basket seem to be normal.
    I did notice that the top edge around the basket in the pump is cracked almost all of the way around (I will be getting a new one). Would that cause any issues? Any other ideas?
    God bless and thanks in advance!!
    22,600 gal. Vinyl Inground, FNS Plus 60 DE Filter, WhisperFlo 1HP Pump, SWG, Dolphin Nautilus
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,115
    Re: Filter Pressure Drop
    Do you have bubbles in the pump basket strainer or coming from your return?
    Mar 2011
    Goldsboro, NC
    210
    Just two bubbles in the top of the pump basket strainer, but I have always had those there. None coming from the returns once I bled the filter.
    mas985's Avatar
    Pleasanton, CA
    11,643
    Did you recently do any vacuuming? Lower pressure can be caused by a partially clogged impeller.
    Mark
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,768
    Tap on the gauge with your fingernail a few times, see if it moves.
    Mar 2011
    Goldsboro, NC
    210
    Quote Originally Posted by mas985
    Not too recently. There hasn't been a lot going into the pool to vacuum, thankfully!
    Quote Originally Posted by Richard320
    I will give that a shot this evening.
    Mar 2011
    Goldsboro, NC
    210
    Okay, tapping on the gauge did not change anything.
    There are some small bubbles coming out the returns by the steps. These are not like the bubbles that come out the return due to the SWG, but more like small air bubbles.
    I have also noticed that the filter is building up air and I need to bleed it whereas I usually do not have to do this unless I am priming the pump. This does not change the pressure gauge before or after, but I figured I would mention it just in case it helps.
    Richard320's Avatar
    Jan 2010
    18,768
    Quote Originally Posted by SPKNout4CHRIST
    Could be you're sucking air somewhere. Less water flow means lower pressure. Start at the obvious. Check the gasket on the strainer. Be sure there's no cracks, no dirt or grass stuck to it, and grease it up good. Also check the drain plugs on the pump and strainer.
    Mar 2011
    Goldsboro, NC
    210
    Took off the pump strainer basket lid and cleaned and greased the o-ring. Put it back on and viola! Pressure is back to normal and the bubbles that had been in the pump basket are gone. Simple fix and I am glad for it! Thanks for the help!!!
    God bless,
    Matthew
