Thread: Hayward s240 high rate sand filter
    Martha_D's Avatar
    May 2012
    Putnam, NY
    67
    I was looking at some videos about pool openings, and noticed that there are plugs that need to be put back into filters. I never did this.
    history: I had someone maintaining my pool last year (which was my first year in the house), and they came by about a month ago on the assumption that they would be maintaining the pool again and did...something. Im not sure what.
    Aside from the fact that I removed the skimmer valve because I thought I had a clog and (I think) put it back on wrong because it seems to be open in the horizontal position, everything has been working ok as far as I can tell.
    My question is for anyone who is familiar with this filter if there are some plugs that I should be aware of?
    thanks in advance...
    34K gallon, Hayward S240 sand filter, in ground, gunite... not sure of pump size and flow rate
    Re: Hayward s240 high rate sand filter
    There is a drain plug somewhere around the edge of the base, you can see it in this diagram as parts 20, 21, 22.
    Martha_D's Avatar
    May 2012
    Putnam, NY
    67
    Ok, I believe that is the waste line... if nothing is coming out of it, does that mean it's ok?
