Results 1 to 9 of 9
Thread: Are Whiperflow motors interchangeable (1.5 to 1.0 hp)
    Jul 2007
    Maryland
    89
    A friend of mine has a Whisperflow pump with a 1.0 hp motor and I have one with a 1.5 motor. He has a 40K gallon pool and mine is about 19k gallons. Are the motors interchangeable? Both motors are currently wired 240V. What else is involved in this type of swap? Anything else besides the motor?
    c ya, grivera
    IG, Cement, 18,600 Gal; DE, SWCG, Nature 2; 1.5 hp pump; Quartz Aggregate, Mid-Atlantic-1st opened 7/07
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Are Whiperflow motors interchangeable (1.5 to 1.0 hp)
    If you put a 1.5HP motor on a 1HP impeller, you'll get performance like a 1HP motor as far as electrical usage and water movement.
    Using the 1HP motor on the 1.5HP impeller will be a problem. The motor will turn it just like the 1.5HP motor, but it isn't designed for that load and may overheat.
    Jul 2007
    Maryland
    89
    What's involved in swapping the impellers?
    c ya, grivera
    mas985's Avatar
    Pleasanton, CA
    11,742
    The impeller is attached to the motor so just leave it on the motor it came with and swap both as a single unit.
    Mark
    Jul 2007
    Maryland
    89
    Would this be a wise move on my part? In other words, will 1 hp be adequate or will I see decreased performance. My intention is to reduce energy costs. I have no water features other than a pressure side cleaner (Polaris 360) and a Heat Siphon heat pump , 2" plumbing wth 90 degree bends. The fella I may trade with has 40k gallons 2" plumbing and wants a stronger pump...
    c ya, grivera
    Unless you have a fountain, waterfall, or spa you haven't mentioned, a 1 HP WhisperFlo will be more than enough for that pool. The smaller pump will use less electricity and just slightly improve your filtering.
    May 2009
    Youngsville NC
    395
    Unless there is a big reason not to - it would be easier to just swap the whole pump(s) and not just the motors/impellers .
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    mas985's Avatar
    Pleasanton, CA
    11,742
    Whisperflo's don't come with unions and are usually hard plumbed with threaded pipe so it is much easier to replace just the motor and impeller and leave the wet end in place so you don't have to re-plumb. Even if both pumps had external unions, I doubt they would be in exactly the same place.
    Mark
    Jul 2007
    Maryland
    89
    Thanks. My motor was already removed for winter storage and he already removed his. We will be comparing them tomorrow and making the swap.
    c ya, grivera
