Results 1 to 10 of 10
Thread: Type of sock for adding CYA
    jccams's Avatar
    Dexter, MI
    95
    Probably been asked before but what kind of sock should I be using to add granular CYA?
    24,000 gal vinyl Lazy L, 1 hp pump, DE Filter, Pentair 250K heater, Letro Legend pressure side pool sweep
    Re: Type of sock for adding CYA
    It doesn't matter a whole lot. Just about anything, from a stocking to a heavy wool sock, will work.
    Feb 2012
    Cypress, TX
    130
    I used a cut up pair of my wife's old pantyhose. It worked great! Pretty funny filling the pantyhose with the 4 lb canister of cya. The little can holds quite a bit when it's put into the hose. It kept filling and filling until the panythose was nearly three feet long.
    23x40 freeform w/spa, 28,000 gal. PCC-2000 in-floor cleaning. Pebble Sheen w/flagstone coping. 14' weeping wall, (2) 18" sheer descents. Sta Rite- cart 400 sqft. filter, Intellipro VS pump, 1hp (cleaning)2hp (water feature)Max E Pro's. Easy Touch 8 function w/IPod. Rainbow chlorinator, Paramount Clear O3 (I know, I know), Max-E-Therm 400K heater.
    Glock30's Avatar
    Apr 2012
    Massachusetts, USA
    90
    Used old tube socks (no holes)
    18' X 36' Inground Pool 26,000 gallons. SuperMax 27mil/27mil Vinyl Liner-Installed Fall 2011
    Pentair Intellipro Programable Pump (Model 011018) // Pentair S8M 500 Cartridge Filter // Circupool RJ45 Salt Chlorinator
    2 Hayward Skimmers // 3 Returns // 2 Savi Melody Pool lights // TF-100 Test Kit.
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    553
    Old tube sock here too. You'll be amazed at how pristine white it is once all the stabilizer is dissolved too
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    This is kind of weird but I recently bought a "Bra Bag" from my grocery store For this exact purpose. It cost about $5 and I found it when I was looking for some borax. It works great for this purpose - fill it up an it fits perfectly in my skimmer.
    It has a zipper closure that seems to hold up well to chemicals and has 2 sides with fine or coarse mesh so you could control the release speed of the chemicals.
    Link: http://www.amazon.com/gp/product/B004W5NU8I
    Above Ground 22,600gal vinyl
    Hayward s220t sand filter w/ 1hp pump
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Traveller... freaking genius... I hate adding all of the solid chems directly to my filter but I know I killed my last liner with solid chems on the floor of my AGP. I am either going to steal the one we have in the laundry room or pinch over to WM to get one for the skimmer basket. Now the kids won't play with it.
    -- Guy --
    Quote Originally Posted by jccams
    I just pour CYA directly into the skimmer. The only downside is you cant back wash for a few days. But I think it dissolves very quickly, probably within 24 hours with water constantly passing over every particle
    17,800 gallon, IG pool, 595 sq feet (17x35x4.5 avg rectangle), Hayward 525 cartridge filter, diamondbrite, 2 hp 2 speed hayward tristar filter, Stenner 45mhp10 automatically chlorinating
    22,387
    The only problem with pouring directly into the skimmer (other than not being able to backwash) is we've had two cases recently where CYA has solidified in the piping partially blocking the flow and had to be chipped out. While we don't see that often, it can happen and people should be aware that it can.
    When pouring into the skimmer, it is also possible for CYA to cause the pump to lose prime or break the pump skimmer basket if you pour too quickly (been there done both).
