I have an idea running through my head that one day I was looking at moving the laundry from the house to out in the Garage. Has it happens, right next to the pool pump and filter.
Question I have; Is there any technical reason that I cannot put the waste water from the laundry done the same waste pipe as the waste from the Pool filter? Apart from building codes (which I have to check up on for here), is there a technical reason not to do this? I cant really see an issue, so long as the existing pool waste was plumbed to the sewage so it can be treated as normal. Would a washing machine make any difference?
N
N
