Thread: Plumbing Laundry / Sink waste to Filter Waste
    East_Akl_Neil's Avatar
    Apr 2012
    Auckland, New Zealand
    70
    I have an idea running through my head that one day I was looking at moving the laundry from the house to out in the Garage. Has it happens, right next to the pool pump and filter.
    Question I have; Is there any technical reason that I cannot put the waste water from the laundry done the same waste pipe as the waste from the Pool filter? Apart from building codes (which I have to check up on for here), is there a technical reason not to do this? I cant really see an issue, so long as the existing pool waste was plumbed to the sewage so it can be treated as normal. Would a washing machine make any difference?
    N
    Late 1970's 39000L IG Concrete Pool with Vinyl Liner
    Austral FT55 Sand filter
    Hurlcon E170 Pump Brochure,Manual
    32-40mm Pipe work
    Living in beautiful New Zealand
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: Plumbing Laundry / Sink waste to Filter Waste
    Here in my area once it hits the sewer it's all headed to the same place.
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
    22,543
    As long as your local code allows it there's no reason not to do it.
