Thread: Pool Skimmer Leak
    Blake1989's Avatar
    May 2012
    Birmingham, Alabama
    135
    Pool Skimmer Leak
    Just got our pool installed, it is an above ground. Filled the water up to the skimmer and noticed a streamline leak was flowing down the wall close to the bottom corner of the skimmer. So can I seal it with an apoxy or putty? Or will I need to drain the water and fix the gasket.
    Above Ground 30' by 54" 22,600
    Hayward S244T Sand Filter w/ 1.5HP Dual Speed Hayward Powerflo Matrix Pump
    TF100 Test Kit
    BBB ALL the way!
    Questions about pool care? Visit Pool School
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pool Skimmer Leak
    Quote Originally Posted by Blake1989
    Assuming the gasket(s) is laying flat, I would try to carefully tighten the screws that hold the faceplate to the skimmer first. If that didn't work I might try some pure silicone sealant (or caulking) as a bandaid for now, however, leaks at that skimmer to pool joint can be difficult to "bandaid". If it continues to leak you may need to drain down below the opening and take off the faceplate to investigate.
    22,553
    As Linen said, you can try to tighten it first but be careful not to over tighten the screws.
    If someone else installed it, I'd have them come back out and fix it.
    If you installed it, did you make sure you put the gasket on correctly?
    Was it a butterfly gasket?
