Thread: D.E. won't coat grids
    I just hooked up a new Hayward EC40 filter to my 16x32 above ground pool. After bleeding all air and adding DE, 4 pounds my pressure was reading 0. I gave it a few minutes and no rise in pressure. Water is returning to pool at what seems to be a normal rate compared to previous years. I was afraid the DE had not coated the perplex tubes so I removed the cover to the filter and all de was sitting at the bottom of the filter. I cleaned it all out and retried. Same results. Pressure equals 0 still. What is going on? Please help
    23,000 gallon gunite with waterfall, radiant heat, sta rite system 3 cartridge filter 450 sq. ft., 1 1/2 HP
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: D.E. won't coat grids
    Any chance the plumbing is reversed?
    From skimmer to pump thru union connection to filter out the top of filter and straight to pool
    22,551
    Welcome to TFP.
    Tell us more about your pool and equipment?
    Is your bump handle operating like it should?
    Is it in the up position like it should be?
    What size pump do you have?
    Is it a 2-speed pump?
    Can you post a pic of the pad?
    The gauge might be broken. Those pressure gauges aren't all that reliable. Even without DE on the grids I would expect to see a few PSI.
    It is possible to have a bad gauge. It is brand new. I will get a new one and see how that works. Later this afternoon I will post more specs regarding my pool equipment. Just dont understand how the DE wont coat the grids. Thanks for the help so far.
