Thread: Plaster
    Aug 2010
    Columbia, SC
    96
    How can I tell if my pool contractor did an adequate job on my plaster? It is a blue plaster and has diffferent textures in different places and the edges arent very even. Should it be this way? Am I overly picky?
    20K Gal Blue Plaster IG with rock waterfall, Beach Entry, Hayward Goldline Pro Logic controller and SWG,
    Sta-Rite System 3 S7M400 cartridge filter, 1-1/2 HP pump, Energy Therm Heat Pump, Nexxus Savi LED lighting
    500 Gal Dynasty Miramax Fiberglass Cinema Spa
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Plaster
    Do you have some pics?
    You're done SLAMing when:
    Mar 2012
    Mountain Brook, AL
    112
    Re: Plaster
    It would help to know when it was plastered and what maintenance occurred in the first month.
    13,500 gallon IG Diamond Brite Super Blue, Pentair Superflo 1.5 HP 2 speed pump, 300 lb Hayward Sand Filter, Hayward Swim Pure+ SWG, Four 4X20 Fafco Solar Bears, Jandy Lite2 NG Heater, Borates, Blue Diamond Robot, TF100 & Refills, Taylor SpeedStir
    Aug 2010
    Columbia, SC
    96
    Re: Plaster
    It was plastered in 2010 and in the first month he did an acid wash and that is all i think was done. I will try to get some pictures uploaded.
