Results 1 to 5 of 5
Thread: What kind of winter pool cover would you recommend?
  1. Back To Top    #1
    My winter pool cover was shot this year when I took it off. So we will be buying a new one at the end of the summer. For the past few years we've used just a typical winter cover with bungie cords tied to the bottom rail of our fence to keep it secure along with some bricks here and there to keep the wind from blowing under the cover.
    Would like to find out what people recommend for inground pools without having to spend a fortune.
    Thanks for sharing!
    23,000 gallon in ground L Shaped Vinyl Pool, Barracuda vacumn, sand filter. Located in Virginia. Member since July 2010.
  2. Back To Top    #2
    Re: What kind of winter pool cover would you recommend?
    Oh... another question... how/where do you store your winter cover during the summer? Last year mice got into ours and chewed some holes in it.
    Thanks again!
  3. Back To Top    #3
    Join Date
    Jun 2007
    Location
    New Jersey
    Posts
    653
    I use a cheap solid tarp-type cover and water tubes since 2004. I always open to a pristine pool. I do recommend a good Rule cover pump which costs a little more. I fold mine up and manhandle it into the basement. Animals will always destroy it if left outdoors around here.
    Bricks are a bad idea. They will wear a hole in a cover in one season. I learned that fast. Water tubes are a pain but they don't do that.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
  4. Back To Top    #4
    About five years ago I bought an Arctic Armor mesh cover for our pool. It involved drilling a half inch pilot hole about every 3 feet around the pool deck, which took some effort. I got it installed in about a weekend. The cost for my 12 x 20 pool was about $350. Our neighbor had a pool company install a Loop Lock mesh cover a couple months earlier and paid nearly $2000 for it. I have compared their's to our Arctic Armor and I see absolutely no difference. Yeah, the install took awhile and I had to buy a concrete drill bit and borrow my neighbor's masonry drill, but it wasn't that tough, and it has held up very well. BTW, they also make a non mesh solid cover, as well as a solid cover with a mesh zippered cutout where water can pass.
    Sent via iPhone with Tapatalk
  5. Back To Top    #5
    Join Date
    Dec 2010
    Location
    Massachusetts
    Posts
    50
    My tarp like cover with water bags wound up damaging the surface of my stamped concrete patio. I guess the freezing temps and water bags adhering to the surface caused the surface to chip away. Bummer! Anyone have any ideas towards this? Thanks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
