Results 1 to 7 of 7
Thread: Cya addition
    Cya addition
    Hi, before I put any cya in my pool I want to make sure I am figuring the pool calculator correctly.
    My cya is in detectable on my Taylor test kit, only goes to 30
    Put the liquid in all the way to the top and can clearly see the black dot
    Pool calc says to add 2 pound 6oz
    Of cya if cya is 25, figuring 25 cause don't want to over shoot the cya and regret it later
    The cya I have says natures way stabilizer 100% cya on the bottle of the granules
    So just wanted to make sure it's safe to add 2 pounds of the granules, figuring this should bring me in the 40 range if it's close to 25 or if it's actually 0 then I can add more next week.
    Let me know if adding 2 pounds is safe, don't want to mess this up )
    Thanks in advance!
    18' x 33' Aqua leader AGP (~19k gal) w/hayward swimpro voyager cartridge filter and 2hp hayward pump.
    8 Gal LQ, hayward heater.
    38,251
    Re: Cya addition
    Sounds right to me ... 32oz of stabilizer will raise CYA by 13ppm in a 19000 gallon pool (using the bottom section of the poolcalculator)
    Smart to sneak up on your intended target
    Cya addition
    Thanks!
    Just added 2 pounds to a sock and put it in front of the return eye.
    38,251
    Re: Cya addition
    Quote Originally Posted by Highlandreef
    Thanks!
    Give it a couple squeezes whenever you walk by to help it out.
    Apr 2011
    Lynchburg VA
    393
    Re: Cya addition
    Watch your PH, it's going to take a tumble!
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    38,251
    Re: Cya addition
    Quote Originally Posted by BadOleRoss
    True the 2 lbs will lower the pH by 0.23 ... not really a tumble, but still
    Cya addition
    Thanks guys, I will keep an eye on it.
    Will turn the deck jets on if needed to bump the ph up
    It is/was 7.3
