Results 1 to 9 of 9
Thread: CYA Testing - Help! Cannot Get Correct Reading
    I've been trying to perform a CYA test for my pool. I have added what I calculate to be a CYA=60 for my pool in stabilizer. My measurement reading at 30 CYA (minimum level) to not be quite there yet. (See attached image).
    [attachment=1:130rbrc3]CYA Test at 30.JPG[/attachment:130rbrc3]
    I also attached an image at 60 CYA mark, and the black dot is definitely visible.
    [attachment=0:130rbrc3]CYA Test at 60.JPG[/attachment:130rbrc3]
    Neither of the two images matches the the photos on the Taylor website. BTW, I took a sample to Leslie's and they measure 60.
    What am I doing wrong? I followed all the instructions from my K2006 kit, to the Taylor website, and the couple posts here as well.
    Shake wait 30 seconds. wait 30 seconds... wait 2 minutes. Hold at waste level under the patio and out in sunlight with back facing sun... Same result.
    30,285
    Re: CYA measuing
    When did you put in the CYA? The test is not valid until 4-7 days have passed.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    6,930
    Re: CYA Testing - Help! Cannot Get Correct Reading
    How much rain have you had since you added? Have you added any water??
    I have a 25,000 gallon pool which I drained and filled 2 months ago.
    I added 4lbs of solid stabilizer immediately after filling.
    Over the course of the last two months, I added 148oz of trichlor shock powder and 15 3-inch pucks. Both are left over from my ignorant days of listening to Leslie's Pool.
    My FC has been between 4 - 6 and CC is 0. I currently experience a daily chlorine loss of about -1.25.
    I use bleach daily.
    Besides the occasional top off from evaporation, I have not filled the water more than normal.
    My stats:
    FC: 5.0
    CC: 0.0
    pH: 7.4
    TA: 150
    CYA: should be 60. I tested many times and do not have a confident level.
    Quote Originally Posted by Leebo
    I am in southern california. We had less than 1-in of rain since refilled. I only topped of the pool due to evaporation.
    Re: CYA measuing
    I added stabilizer power 2 months ago. I finished off 148 oz of trichlor shock powder about 1 month ago, and the last of the 15 trichlor puck just finished dissolving 2 days ago.
    30,285
    I have not done the math so there could be a calculation error.
    The bigger point for now is to trust your own testing. If you can see the dot @ 60ppm, you don't have 60ppm and need to add some.
    It sorta' looks to me like I can see the dot at (I assume) the 30ppm mark so you may not have 30, either. Even if we can't solve the mystery right now, you need to add enough CYA to get to 60ppm.
    I used the pool calculator extensively.
    Please help me do my math.
    25,000 gallon pool
    stabilizer 4lb = 4 * 16oz = 64oz = 19 CYA
    trichlor powder = 148 oz = 25 CYA
    trichlor tablets = 15 * 7 oz = 105 oz = 17 CYA
    19 + 25 + 17 = 61 CYA.
