Results 1 to 12 of 12
Thread: Filtering 24/7
    Apr 2012
    Lees Summit, MO
    21
    Filtering 24/7
    Should I not be doing this?
    20x40 inground, fiberglass 3 foot down then vinyl.
    33,000 gal
    BBB
    1.95HP Hayward Super II pump
    Sta-Rite System 3 DE 37 sq ft
    Jandy Lite 2 400 Natural Gas heater.
    38,254
    Re: Filtering 24/7
    Are you shocking? If not, then running your pump all the time is likely just costing you money.
    Try reducing the run time until you are not happy with the cleanliness of the pool (skimming, particles, etc) and then bump up the time a little more. I would almost be willing to bet you could get by with less than 12 hours.
    Apr 2012
    Lees Summit, MO
    21
    Re: Filtering 24/7
    I am not shocking. I usually just run it 24/7. I'll turn it off during the day tomorrow. I do likes it clean though.
    33,000 gal
    BBB
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Filtering 24/7
    Quote Originally Posted by jdelana
    Well, I know I should not do this, but if I had to guess the average filter time (reported on TFP) , it might be somewhere between 6 and 12 hours daily.
    nevermind, I'll go ahead and hit myself on the head for guessing....
    No, wait. I did spend the night at a Holiday Inn Express last night! not.
    But, I have read lots and lots and lots at TFP over the years
    You're done SLAMing when:
    38,254
    Re: Filtering 24/7
    You can save up to 50% on your electrical costs by switching to TFP (suggested pump run times) ...
    This is the "quoting commercials thread" right?
    {Hey look at that ... and it was my 1500th post}
    Apr 2012
    Lees Summit, MO
    21
    Re: Filtering 24/7
    Is this going to require I use a hand skimmer? If so ill swallow the extra cost. Lol
    33,000 gal
    BBB
    38,254
    Re: Filtering 24/7
    Well, probably not too often. Especially if you split the run times so the surface is skimmed multiple times per day.
    Apr 2012
    Wichita Ks
    29
    Re: Filtering 24/7
    Is it better to run at night or during the day? Not asking from a cost standpoint but rather from a whats best for the water?
    23k Vinyl, Sand Filter tr60, 1hp Whisperflo pump,Coverstar autocover
    Polaris 280,K2006 kit,direct sunlight
    38,254
    Re: Filtering 24/7
    Does not seem to matter, there are theories of minor benefits each way.
    Try running it 6 hours in the day and 6 hours at night
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,766
    Re: Filtering 24/7
    ^I am about to experiment with weaning off the 24/7 pump thing as well. Stage 1 will be 12 hrs. straight.
    My first experiment will be to see if A) at night the frogs can find their way out if they're NOT sucked into the skimmer so they can await and welcome me each morning and B) Cover Free retains enough heat that I can avoid a solar cover and live with the gas bill.
    Ergo I will be shutting down the pump at night and timing it to start up the next morning for a spell. I get a lot of leaf debris, so we'll see whether it accumulates most during the day or the night
    In
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Apr 2012
    Lees Summit, MO
    21
    Re: Filtering 24/7
    I tried it over a day. Came home to a dirty pool. It was really windy. Sooo ill probably just leave it on. Cept for some calm nights.
    33,000 gal
    BBB
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,766
    Re: Filtering 24/7
    So far shutting down at night is working for me...and the frogs. I'm no longer playing "who's in the skimmer this morning?" Some mornings do require a bit of hand skimming to save debris from the filter, and as yet I'm unsure if this will mean more vacuuming.
    However, the foregoing has not stopped the local wildlife from drowning itself during the day when I'm at work Do these animals not communicate with each other? Like, hey buddy, watch out for the pool, Red died in there the other night... Chipmunks in particular seem to have no concept of caution!
    Helpful Links:
