Thread: Cyanuric acid to a vinyl pool
    So you can add cyanuric acid to a vinyl pool, (if needed)...
    15 x 30 oval above ground, 13000 gals, 1 HP pump, sand filter.
    Re: Cyanuric acid to a vinyl pool
    It is completely fine to cyanuric acid in the water in a vinyl liner pool. Nearly all vinyl liner pools do. However you don't want to put granular cyanuric acid directly into the pool so it sits on the bottom. That could damage the liner.
