Results 1 to 15 of 15
Thread: What is this stuff??
    May 2009
    Mn
    198
    Put Rover jr. in to do some cleaning ("shocking process is now over, cholrine coming down and Water boatman back in the pool ) Attached is a picture of the "white chunks" that it is picking up. This has happened one other time last week. What is this stuff?
    I added DE to the filter, but DE is much finer than this isn't it? It almost has a texture of brittle plastic with a bluish tint. Could the liner scale off?? My numbers are actually better than ever right now.
    Thanks!
    24' Round Diamond Star, 54" wall height, 200sq ft sta-rite cartridge filter
    Dynamo 1hp 2 speed pump, 199k Rheem milivolt heater
    Pool rover jr. - our best friend!
    Tf-100 plus borate strips and Taylor k1000.
    Feb 2012
    Stowe, VT
    59
    Re: What is this stuff??
    I can't seem to find the attached image. Perhaps try re-posting?
    [edit]
    DE is definitely much finer than this. It does clump together but not necessarily in such a solid form. Have you added any CYA lately?
    69,000 Gal gunite indoor IG pool.
    5 HP Emerson - Pentair Triton II Commercial TR140c Sand Filter x2
    5,000 Gal gunite outdoor IG hot tub
    2 HP Sta-Rite - Pentair Triton II Commercial TR140c Sand Filter
    Feb 2012
    Phoenix, AZ
    728
    Quote Originally Posted by MNPoolDreamer
    What ARE your numbers?
    Is it pollen season in your area? I know we have tons of cotton wood landing in our pool. It clumps together horrible. I usually clean my sand when it is over and it looks like a dead cat. Always fun times
    17K gal, AG, Hayward Sandfilter, new to the BBB method.
    May 2009
    Mn
    198
    It's not pollen. It's almost like plastic from something. Very sharp edges sort of like a cheap plastic cup that gets brittle over time and then disintegrates into shards. I'm worried it could be from the liner as it has tinged of blue to it.
    We only swam for a few minutes last night but this happened earlier and we had not been swimming
    My fc was as follows:
    5/19. 5/20 pm 5/21 5/21 pm 5/22 am 5/22 pm today am
    17. 31. 31. 17. 23. 19 (went swimming and added tap h20) 17
    Cc has been 0 or less than 0.5 as it was super light pink
    Ph was 7.5+ so I put in 2 lbs dry acid (mixed before adding)
    The water is (was until it just rained) crystal clear. Better than it has ever looked.
    TA 175
    Ch 325
    Cya 40
    May 2009
    Mn
    198
    Could it be calcium scale built up in the heater and now that we cranked the heat it's coming off? Sort of makes sense cause I told hubby that the water coming out just doesn't feel very warm. Sort of an expensive way to remove the scale though!
    The heater will cost me over 10.00 per day to run.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Got an eyedropper? Put those chunks in a glass or ceramic dish and put a few drops of muriatic acid on them. If they foam up, it could be scale.
    I've seen similar stuff as a crust, not as loose chunks, from corroded metals - aluminum and zinc - used in pool stuff, like brush handles. It might be worth a look around the pool shed.
    May 2009
    Mn
    198
    Yep, it's scale from the heater. Did some more research and fond a picture almost identical to the junk I was getting. Bad news, we have a lot of scale,despite using inhibitor last summer. Good news, it's coming off. Now we just have to figure out how to ditch our hard water.
    Type in scale in hot water heater, look for images and you'll see the same bluish colored flakes.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    As we have discussed before, get that TA down and you will have much less problem with scale Then you won't have to "ditch your hard water".
    Why the high FC...are you shocking right now?
    All you other test values look good though.
    May 2009
    Mn
    198
    We were shocking cause I had water boatmen in th water. I was convinced that they were eating algae that I had no evidence of having...just being defensive about bugs using my pool.
    I've been working on the TA but every time I stick the hose in to add water due to evap or backwashing I'm starting over with iron, high TA and calcium. We are seriously considering using our softened house water for top offs, but I don't know if it can handle that much use.
    Thanks for all the support and help. I have almost given up a few times but the guidance and direction here keep me sane. I'm so jealous of people who have good water!
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I have not seen a lot of success in posts here that suggest boatmen will be repelled by chlorine.
    Remember do not backwash until your pressure goes up 25% from you clean pressure. I would guess if you maintain you FC level properly (for your cya level) you will not have to backwash a whole lot. Maybe consider using a skimmer sock to catch some of the junk pre-filter.
    This is not a bad idea, just make sure you understand how often you need to regenerate to feed the pool make-up water.
    Me too, but a least both our water sources are cheap. As I have mentioned to you before I start a little higher than you with my fill CH and TA (and I have some metals) but, with proper TA adjustment, I end up having no problems with it.
    West Michigan
    108
    IMHO The only way to get rid of boatmen is to have borates in the water. When we get balanced and have borax in our pool we never get those water bugs. Just follow the directions here on the forum and hang in there...
    5 years 18' Intex Frame pool, July 2009 upgrade, 28ft rnd used Doughboy, 1hs Hayward Power Flow pump, Doughboy DE filter.TF test kit
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    I have to agree with kim, we had boatmen/waterbugs last year and I brought up my borate leve and no more bugs!
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    May 2009
    Mn
    198
    What level are your borates at? We are at 30. I haven't added any this year and that's where we were at last year. I'm just worried about toxicity since we have little children swimming in our pool.
    The boatman are so bad they were bonking me on the head while I was vacuuming, and they were landing in the driveway when my husband was washing some stuff off with the hose!
    We live near a lot of swamps so we are just going to come to peace with them being part of our pool. Along with dirt from the farmer.
    By the way, the TA is down to 125 and I think most of the scale is out of the heater. Rover picks up all the chunks so we are on our way to a fun pool season.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I would guess your level is lower than that, especially if you drained for winterization. I was at 50 last summer and between draining for winter and backflushing this spring I went down to 30 ppm.
    Take a look at this thread: http://www.troublefreepool.com/borat...ey-t13695.html
    Way to go I would still drop it at least to 100 ppm.
