Page 1 of 4 1234 LastLast
Results 1 to 20 of 69
Thread: First Time Shocking with Bleach
    After struggling every summer to keep my pool clear, I'm ecstatic I've found this site to help me. Hopefully you guys will be patient with me until I get the hang of it, but here goes nothin'.......
    FC- 3
    CC- 3
    Ph- 7.2
    TA- 120
    CH- 140
    CYA- 60
    Water color is blue-green and slightly cloudy with no visible algae on the walls or floor.
    These results are from Leslie's and I have a TF-100 on the way. Using the calculator, I'm assuming I need to get FC to 18ppm to begin the shock process. The calculator says I'll need 778 oz. of 6% bleach.
    Here are the questions... should I raise the ph and/or Ch before adding the bleach? What are the possibilities I'll be finished with the shock process and have FC back down to swimmable figures by Sunday?
    Thanks for the help in advance!
    28K IG Gunite, 60 sq. ft. Pentair DE Filter, 2.2hp WhisperFlo Pump, Polaris 3900 Vac in Baltimore, MD.
    Re: First Time Shocking with Bleach
    Leave the PH alone. You can add some CH before you start shocking, or wait, just don't add any during shocking.
    It would be good to double check that CC reading. I don't totally trust any pool store test results.
    If things go well you could easily be swimming by the weekend, but there isn't enough information here to really be sure. CC will often go away very quickly, but it isn't clear where the CC came from, and some possibilities there could lead to complications.
    I guess I'll just wait till the TF-100 gets here before I do any thing drastic if you're saying the CC looks odd.
    ok got my tf100 a few days ago and am now ready to go....
    CYA- 48
    FC- .5
    CC- 1.5
    PH- 7.2
    TA- 120
    CH-230
    So using the Chlorine/ CYA chart I'll be shocking my pool to 20 FC (rounding up from 48) using 1011 oz. of 6% Bleach. How often should I test after the initial dosing of bleach?
    Smykowski's Avatar
    Sep 2011
    3,065
    I'd do the first test an hour later. The amount of FC you lose in that first hour will kind of set the pace for your testing through the rest of the shock process.
    Bleach is in... BTW here's a pic... pool is clear with a slight green tint to it.
    [attachment=0:321s17l2]1st pool pic.jpg[/attachment:321s17l2]
    Hey! Why'd my hose come off of the Polaris?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Quote Originally Posted by Jerry Lee
    CYA- 48
    FC- .5
    CC- 1.5
    PH- 7.2
    TA- 120
    CH-230
    I predict a quick victory. You have the test kit, the understanding, and the pool calculator.
    Check it in an hour, see how much FC you lost and how much you need to add to replenish it. Then adjust the interval so you keep it within 3 of the target.
    Don't forget to brush, that knocks the skin off any slimy algae on the walls. And toss any pool toys or tools in for a soak - get it all.
    Thanks for the help! On my way out to brush.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Watch for color changes, as the process goes on and keep us updated.
    ok 1 hour later I have...
    CYA- 35
    FC- 3.5
    CC- 10.5
    PH- 7.2
    TA- 120
    CH- 230
    Still aiming for that 20 FC. Should I hit it again with 855 oz. of 6% ? And do I need to keep testing for TA & CH?
    Smykowski's Avatar
    Sep 2011
    3,065
    First, please post lots of pics, cause yours is going to be a good one when it's done.
    Now, to the bad news. Huge drop in FC and huge increase in CCs in that short of a time means lots of nitrogen in the pool, likely ammonia. Prepare yourself for lots and lots of bleach. This thread is a good example of how this might go. My point is not to scare you, but to prepare you.
    Add the bleach, and test again in another hour.
    No. Shock levels of chlorine won't change them, so save the reagents until you're done. You can also stop checking pH until you're done as well. The test is inaccurate at high FC levels, and it also won't change enough during the process to worry about. It was fine when you started, so you can assume it will stay fine until you're done.
    Yikes!!!! I'll try to take a picture after each test. I guess I'm on my way back to Costco well.
    [attachment=0:3a3u2km5]2nd pool pic.jpg[/attachment:3a3u2km5]
    By the way, to the right of this picture is my empty dive stand and a broken 10' S.R. Smith diving board next to it.
    I found that 10% at Meijer is cheaper than 6% clorox at Sam's Club.
    Try checking around for the best price since you will be using lots of chlorine. Think if you were to go in to a pool store, here try this $XXX worth of chemicals..
    (it's actually not that expensive )
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Test #3 5:35
    CYA- 40
    FC- 5.5
    CC- 13
    Anyone have a forklift?
    [attachment=0:2pamd5k5]3rd pool pic.jpg[/attachment:2pamd5k5]
    22,551
    Keep the faith.
    Smykowski's Avatar
    Sep 2011
    3,065
    We like it when people win the battle against junk in the pool. Keep at it, and I'm sure you will have a lot of people rooting you on.
    Keep it above 20!! The less often it drops below that, the faster this process will take.
    If you ever have doubts, reread that thread I linked above, or better yet, pm Johnny-M directly.
    Test #4
    CYA-55
    FC-2.5
    CC-11
    Is it normal for the CYA to be moving around so much?
    [attachment=0:647skukb]4th pool pic.jpg[/attachment:647skukb]
    Richard320's Avatar
    Jan 2010
    19,037
    Test #4
    CYA-55
    FC-2.5
    CC-11
    No. It probably isn't, and you're wasting test reagent checking it all the time. Unless you are using something other than liquid bleach to raise FC?
    Ignore everything but FC and CC until it clears up.
    I can assure you, it's been all...
    [attachment=0:2de769gp]clorox.jpg[/attachment:2de769gp]
    I'll just stick with 20 being my shock level. I'm glad I bought the XL tf-100.
  20. Back To Top    #20
    Richard320's Avatar
    Jan 2010
    19,037
    You ain't got nuthin' on this guy!
