Thread: Please help a newbie with a solar and SWG question
    Guest
    First time posting here and I'd like to thank everyone for all of the great info on this site.
    This is my first season my our new inground pool (we live in the Toronto Area). I have a 14x12x28 mountain lake shaped pool with a waterfall, a 5 foot "deep" end and solar on the roof and so far we love it.
    Now onto my problem...
    There is little to no chlorine in my pool.
    The solar valve actuator turns on and off 4-5 times in a typical 20 minute span. Every time it turns off, my SWG (Hayward T-15) turns off for 3 minutes! As a result I do not have enough chlorine being produced.
    My pool contractor says there is a problem with the solar valve actuator (that it shouldn't be turning on and off like that) and that the SWG turns off for 3 minutes each time as a safety feature. My solar contractor says that my pool pump (Hayward 1hp Superpump) is a little underpowered in terms of flow and that if I upgrade to a 3/4 hp Tristar pump my issues will go away.
    So, I have two people basically pointing the finger at each other and no chlorine in my pool.
    Can anyone help me out with this?
    Jan 2010
    Northern Virginia
    282
    Re: Please help a newbie with a solar and SWG question
    Dump a couple of gallons of bleach in the pool to take care of your chlorine problem. Go to the pool calcutator on this site to determine how much.
    Unfortunately I can't help with the second problem.
    Did the pool builder know you were going to be using solar? If so he probably should have up-sized your pump. But I'm no expert and I don't even know if the "underpowered pump" theroy holds water.
    700 sq. ft./30,000 gal, gunite pool; 48 SF DE filter; 1.5 HP pump; Salt Water Generator; Solar Heat
    38,252
    There a few possible causes. The actuator gets turned based on whether solar heat is available AND needed. If your pool is very close to the desired temp, I can see the solar controller asking for heat and then not and then asking ... etc, but there is usually logic in the controller to avoid this constant switch back and forth (think of it like your thermostat in the house ... there is a buffer around the desired temp otherwise the heater would kick on and off all the time).
    If you bump the desired pool temp up (or down) does the actuator cycling stop?
    I would think either the solar controller has a problem, or a temp sensor has a problem.
    Making the pump bigger would not change anything as far as I can tell ... besides costing more to run.
    Supplement your FC with bleach while trying to figure this out.
    Guest
    Thanks guys...will do on the bleach.
    I thin it is the solar temp sensor. I was fiddling around with the menu and went through to the diagnostic menu. The solar sensor temp was all over the place so I called and they are coming to replace the sensor. Hopefully that fixes it.
