Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Throwing K-2006 test water back into the pool.
    I've always seen people do tests at the side of the pool and throw the tested water back into the pool, but I've read that you're not supposed to do this. It obviously makes sense that pouring the tested water and chemicals down a drain would be "best," but I'm still curious how much effect this practice can have on pool chemistry when doing the various tests with the Taylor K-2006 kit. It strikes me that I've never even seen any mention of this in the Taylor instructions, and I was always under the impression that this had a negligible effect on pool water. Are there certain tests in this kit that are worse than others when doing this?
    Larry
    Los Angeles, CA -- 22K gallon in-ground plaster pool with spa, built around 1980, replastered around 2009-2010.
    Pentair Intelliflo VS (variable speed) pump and Quad 100 DE filter. Older "MiniMax" gas heater. Pentair Rebel cleaner.
    NO SWG - Liquid Cl only. Taylor K-2006 test kit.
    22,544
    Re: Throwing K-2006 test water back into the pool.
    Some of the reagents are poison and really shouldn't be put in the pool. However at the levels you're talking about it's probably not an issue.
    Here are the msds for the chems in the kit.
    Jun 2007
    New Jersey
    653
    Quote Originally Posted by lalittle
    Larry
    5. Do not dispose of solutions in pool or spa.
    From K-2006 Test Kit instructions: http://www.taylortechnologies.com/pr...er&Number=5138
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Quote Originally Posted by Durk
    Ah -- I hadn't seen that. I don't remember seeing that precaution in the printed instructions, and after a cursory look just now, I still didn't see it in the booklet. It could still be in there somewhere, but it might just be in the online instructions.
    Unfortunately, it's not easy to tell all that much from the msds sheets since they tend to deal with worst case scenarios rather than with "real world" exposure. I kind of doubt that most people use the recommended lab coat, gloves, and safety goggles when testing their FC levels.
    Thanks again,
    Larry
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Why do it squatting uncomfortably? I use a chunk of PVC pipe as a giant pipette and fill a measuring cup with sample water. Then I carry it over to the patio table and run my tests at my leisure while sitting comfortably. The ashtray is optional, but having a smoke makes the CH test seem less lengthy.
    Just be sure to keep the sample away from the coffee mug, they're easy to confuse when you aren't paying attention.
    Apr 2012
    Mason, Ohio
    119
    Quote Originally Posted by Richard320
    And all this time I've been getting flat on the ground, reaching down into the pool as far as I can, getting my shirt all wet... This is genius!
    34K gal IG, 37'x40' lagoon, vinyl, Pentair IntelliFlo VS Pump, 500# Hayward sand filter, Jandy SWG, Raypac heat pump, 4 deck jets, Hayward Super Pump + deck fountain, Dolphin Oasis Z5
    22,544
    Look for the word "toxic" that's the ones you don't want to be throwing back into the pool! The DPD reagent is the biggest reason but I don't dump any of it into the pool.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,082
    Why do it on the patio table? Take the sample inside to a well lit room. I myself use a white poster board and test on that. The white makes it easy to see the color changes happen, and testing indoors will help the reagents last longer.
    Richard320's Avatar
    Jan 2010
    18,984
    Quote Originally Posted by Leebo
    I don't smoke in the house, that's why!
    Jul 2011
    Eastern Ohio
    7,082
    there you go
    If you don't smoke....test indoors.
    If you smoke....test outside.
    May 2011
    Massachusetts
    19
    I test outdoors, too, but don't smoke. I just like to sit out on the patio near the pool. I have a white pad of paper that I use to write down my numbers and to see the pretty colors better.
    13500 gal 15x30 oval AG, Hayward DE filter
    Apr 2012
    Mason, Ohio
    119
    Quote Originally Posted by cillovely
    I do the same - except I record everything in my iPad - which makes a great light box / white background for seeing the colors.
    Jun 2007
    New Jersey
    653
    I always test IN the pool. If the weather is bad, I just guess. I've been at this long enough that I never have a problem. Being in the pool makes things a lot easier. I use the white plastic skimmer cover as a background. Then I chuck the used test solutions through the fence into the field, never in the pool.
    Jun 2007
    New Jersey
    653
    Thanks again,
    Larry
    I just got back from testing at the pool. You can find that sentence on the inside cover of your kit on the black stripe across the top. I took a quick look in the booklet and I don't think it's in there, but it is on the blue box.
    So now the question is: How bad is it that I was tossing everything back in the pool for nearly a year? Is there any risk of the toxic chemicals building up over time, or do they dissipate/breakdown? Is it worth draining some amount and refilling in order to dilute what's there? I was doing this for quite a while (as I said, close to a year), but I simply have no point of reference for how potentially bad things could be at this point.
    Thanks again,
    Larry
    22,544
    Maybe Richard (Chem Geek) will see this and impart some of his knowledge about it.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I've always thought that chlorine will break down the reagents...I await the actual truth!
    reagan's Avatar
    May 2011
    NE Ohio
    64
    Do you use a specific app to keep track? I'd kind of like to do the same, since I have WiFi and can use the PoolCalc site on my iPad when I'm outside. (The app doesn't have very good reviews and doesn't retain the pool size, according to the reviews. )
    BBB/TFP/Taylor K-2006 Evangelist!
    6/13 - Installed AG Sharkline Heritage 21'x54" 11K gallons. Hayward 1660s sand filter, Hayward single-speed 1 hp pump; city water. Husband builds, I maintain.
    5/11 - Starter pool 6000-gallon Intex Ultra 16'x48" AG with standard 1500 gph 1/3 hp cartridge filter.
    reagan's Avatar
    May 2011
    NE Ohio
    64
    Quote Originally Posted by Mike_k
    I'm 5' nothing and have to stand on tiptoe to shove my arm way down into the pool... I'm going to have to Bogart a length of DH's PVC for this purpose.
  20. Back To Top    #20
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Hello all~~
    I test year round. I take the sample from a sampling station on the equipment pad. All the testing gets done inside in the brightly lighted white kitchen, which gives me the same conditions day or night, sunny or raining....
    The remains go down the drain with water running to dilute.
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
