- May 23, 2012
- 8
Trying to hook up a new sand filter to a summer escapes pool. 18ft. Is this possible and how. I need basic terms would be appreciate. New pool owner. Thank you!
Flash10325 said:I am trying to load a picture trough my iPhone. Having trouble any help here?
Flash10325 said:We really don't want to cut our pool if possible. At this point we have clamped through the old filter system. Took the impeller out of the motor. Hoping this works
Flash10325 said:Did you take te impeller out of the old filters motor?
Same here!Flash10325 said:Well we hooked it up like I said trough the old filter system. We just clamped it off very tight from the motor hole. It runs great.
Flash10325 said:I dunno, but when I vacuum I will connect inside the filter at the bottom, rather than to the hose attachment you set in top
