Results 1 to 12 of 12
Thread: CYA from Home Depot
    22,550
    Re: CYA from Home Depot
    It depends on what you're trying to do. If adding CYA is all you're wanting to do then that's not what you want. Stabilizer or conditioner is what you want. The ingredients will be 96% cyanuric acid or more.
    Mar 2010
    Spring, TX
    1,082
    Here is what you are looking for I believe
    http://www.homedepot.com/Outdoors-Outdo ... ifications
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    Quote Originally Posted by mynewpool
    They don't have that at any local home depot... What about at lowes? Any other brand I my find at home depot or lowes?
    22,550
    As long as it's 95% or better cyanuric acid it's fine to use. Most big box stores will sell it. Also most pool stores have it. The last I bought was from Ace hardware.
    Would you happened to know a brand name for home depot or lowes?
    22,550
    They change brands from time to time and different locations have different brands so If I told you it was HTH it may be Aqua-Chem at your store. The brand really doesn't matter.
    Apr 2011
    Lynchburg VA
    393
    I picked mine up at Lowe's a few weeks ago.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Quote Originally Posted by BadOleRoss
    What section of the store
    Mar 2010
    Spring, TX
    1,082
    You could also try walmart as well.
    Apr 2012
    Mason, Ohio
    119
    This is where I get mine as well.
    34K gal IG, 37'x40' lagoon, vinyl, Pentair IntelliFlo VS Pump, 500# Hayward sand filter, Jandy SWG, Raypac heat pump, 4 deck jets, Hayward Super Pump + deck fountain, Dolphin Oasis Z5
    Apr 2011
    Lynchburg VA
    393
    Quote Originally Posted by ac09lude
    I am in Virginia and the store around here carry it in the Outside Lawn and Garden area with the pool chemicals. It will say "Stabilizer" right on the bottle. Just make sure the ingredients are CYA.
    Pool School
    Pool Calculator
    Test Kits
