Thread: Intex A Filter Replacement
    May 2012
    Kitzmiller, MD
    6
    Good Afternoon everyone,
    I'm Joe. I just put up my first pool of any kind this past week. Of course the hardest part was getting the ground level. I was about 16 inches off, so instead of digging out the lowside, I built a box our of treated 2x6's and 4x4posts. Then I filled that in with #57 gravel, drove my truck, my ATV, my ATV with loaded wagon, my own 2 feet on top of that every so many inches to tamp it down. Then I finished that with about 3 inches of masonry sand, put down pavers, setup the pool.
    I now have the pool filled up from my own well. That went surprisingly fast. My water has alot of iron in it. I am working on that, actually my wife is. She showed an interest in treating the pool. I got out of the way as quickly as I possibly could.
    My problem is the replacement filter. I bought 2 at Walmart for the Type A,C pump. I wanted to have them ready because I knew how bad the water is. The new filter hole is much smaller than the installed filter and won't fit down in there. Am I doing something wrong? Did I get the wrong filter? If I purchase the Unicel-4607, will that work?
    Also, I appreciate this forum. It helped me plan out the process of setting the pool up. Especially the post about putting the top frame together to set the pavers. What a brain saver.
    Intex Ultra Frame AG 14x48, 4000gals, Intex 2500gal pump
    Re: Intex A Filter Replacement
    Walmart filters are summer escapes brand. Just enlarge the hole with a box cutter. I can upload pics if you need a visual but as long as you leave slight ridge outside the first ring, the filter will fit securely.
    ~25,000 gallon
    In Ground Pool
    Gunite/Plaster/DE Filter
    Using a TF-100XL from http://tftestkits.net
    Dolphin Dynamic bought 4/2013-pretty happy with it
    May 2012
    Kitzmiller, MD
    6
    Why didn't I think of that? Thanks!
    Glad to help
    And if you haven't read this yet- reuse those filters! Spray clean, soak in bleach water for a few hours and air dry.
    ~25,000 gallon
    In Ground Pool
