Thread: Clorox PPM recommendation ?
    May 2012
    York Pennsylvania
    45
    Clorox ultra is made for pools, so says Clorox. The recommend 2 PPM and not to exceed 4 PPM for bather safety. These leves are lower then the calculated reconditions Can someone explain this? I know I'm at 6 PPM in my pool.
    Found the information in Clorox extended use directions for bleach.
    Dave S
    24x52" Round AGP
    Hayward S244T 300 pound sand 1 HP matrix pump
    Taylor K-2005 Test kit with the K-1515-A FAS-DPD added on.
    No one is useless, you can always serve as a bad example!
    22,548
    Re: Clorox PPM recommendation ?
    Along with the rest of the pool industry, they don't recognize the chlorine/CYA relationship so they recommend as if there were no CYA in the pool at all.
    Butterfly's Avatar
    South Carolina
    10,045
    You can also find lots more info on CYA/Chlorine relationship over in the Chem 201 forum.
    You're done SLAMing when:
