Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: Pentair "Clear-pro Technology", Sand Filter, Normal Pressure?
    Jun 2011
    Ste-Marthe-sur-le-Lac, Quebec
    38
    Hi to all,
    I have a Tagelus TA60 with clearPro since 2 years and alaways had a hard time besause of high pressure (25 psi -27 psi after 5-10 minutes backwash and 45 sec. rinse).
    When running in recirculate mode, pressure is around 12 psi.
    Is it normal a 15 psi difference between recirculate and filter for this type of filter?
    If I fill with gravel + sand should it reduce pressure?
    Even new it was running at minimum 24 psi.
    Please help me because of high pressure I need to backwash everyday because heather stop to work with the flow error message.
    Here is my equipment:
    Superflo 1.5 HP
    Summit SUM 3 heat pump.
    Thanks.
    22,553
    Re: Pentair "Clear-pro Technology", Sand Filter, Normal Pres
    25 psi seems high but I have no experience with the Clear-pro filters.
    12 psi is high in recirc mode. Can you tell us more about you pool and equipment? How far it is from pool to pad, what size piping you have, etc.?
    Jun 2011
    38
    Hi,
    My piping is 1 inch and half, distance from pump to skimmer / drain is around 35 feet.
    I posted a picture of the setup let me know if you need more info.
    Thanks.
    22,553
    I'm not seeing where you posted the pic.
    Dec 2008
    82
    That pressure seems high to me even in recirculate (bypassing the filter). I wonder if you have a restriction on your return side.
    The clear-pro system exchanges the slotted laterals in favor of laterals that are made of porous material which will filter down closer to DE filters.
    Jun 2011
    38
    Sorry about that cant seem to be able to upload.
    https://picasaweb.google.com/1041099295 ... directlink
    Thanks.
    22,553
    I seem to remember seeing that setup before. Or one just like it?
    Can you bypass the heater? If so what does the pressures read then?
    Jun 2011
    38
    Quote Originally Posted by cadillac
    When in recirculate or filter, water seem to go back to the pool without restriction (don`t have any problem to vacum either), I have a jet in the stairs and I keep it always open.
    Jun 2011
    38
    The heater was bypass when doing the test.
    Jun 2011
    38
    Another comment:
    My pump seems to be working hard because of the high pressure, because when in recirculate it sounds to run smoother.
    Thanks!
    Jun 2011
    38
    need-to-always-backwash-t34431.html
    22,553
    It sounds like a restriction in the return plumbing somewhere [s:2lf8g0ad]especially since it wasn't that way last year[/s:2lf8g0ad]. Oops, I see it was that way last year.
    You said it was algae last year when you had a problem. Do you suspect it could be again?
    Dec 2008
    82
    I though this all sounded familiar.
    A normal sand filter will let dead/alive algae right through, but a clearpro will catch it all.
    Jun 2011
    38
    It sounds like a restriction in the return plumbing somewhere [s:2a2pm3po]especially since it wasn't that way last year[/s:2a2pm3po]. Oops, I see it was that way last year.
    I did shock, got water checked, its all balanced...
    Since I have this pool I need to backwash every 2 days other wise FLO error message on filter.
    Could I try to run filter without any sand....would pressure be lower?
    22,553
    You don't want to run it without sand.
    Have you broken the filter down and looked closely at the laterals?
    Dec 2008
    82
    When you shocked, did you follow the method here?
    pool-school/shocking_your_pool
    Bama,
    On your pool, what is the filter pressure on recirculate normally? You have a very similar system.
    Jun 2011
    38
    twice already, should I do it again tonight, maybe change sand at the same time?
    Jun 2011
    38
    Yes I did.......
    Bama,
    22,553
    My normal filter pressure runs about 11 psi and about 5 on recirc. I'll check it this evening when I get home. I'm going swimming!
  20. Back To Top    #20
    Jun 2011
    38
    Talk to yet another tech a Pentair, he says the 13 psi on recirculate is quite high, it should be more like 5.
    He says to check all the ball valve, maybe they don't open completly. => will do tonight.
    He says to make sure using #20 sand => I will change it tonight.
    Clean laterals using soap and water. => will do tonight.
    I will post after!
