Thread: Cartridge cleaning question
    Nov 2007
    Rockland County, NY
    65
    Hi All
    My filter psi is normally about 12. After a AA treatment I noticed the pressure was at 16 so I decided to clean the two carts in my Sta-Rite 500sf filter. Tons of junk from a messy opening, but the last time I did this I remember being able to get the pleats much "whiter"....certainly not like new, but noticeably cleaner. This time the pleats remained a fairly dark brown after all the other debris was washed away. This is our fifth season. Is it possible I just need a more aggressive cleaning via the overnight soak in TSP? Can iron or iron precipitates clog the filter material? Thanks
    27ft Above Ground Pool
    Sand filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Cartridge cleaning question
    The most important thing is the pressure after cleaning. Did it drop back to 12psi? If it did, and you don't see a shortened cleaning interval, you are probably fine. If the pressure is high or the cartridges need cleaning often, you may need to do a soak, or even possibly a soak and acid wash if your calcium level is high.
    Nov 2007
    Rockland County, NY
    65
    Sorry.....forgot to include the most important fact....PSI stuck at 16
    Sand filter
    Jul 2011
    Indianapolis
    63
    I would suggest a soak. How are you cleaning th filter? Garden hose and nozzle? Are you letting it dry before using it again? Do you have two that you rotate?
    19000 gallon IG installed in 2003, owned by me since 2010, vinyl liner, 18x36, Sta-Rite PLM-150 cartridge filter, 1hp AOSmith motor on <brand unknown> pump, automatic cover, BBB since August 2011
    There are good instructions on cleaning a cartridge in this topic.
