Results 1 to 11 of 11
Thread: CYA Quick question.
    May 2012
    Small midwest town In illinois
    55
    CYA Quick question.
    I read it takes a week after adding (solid) for it to be an accurate test. But, my husband tested the CYA 24 hours after adding and it showed results, of 50. (I am having to do a lot of explaining of this new method to him) This is not an accurate, correct?
    I was at zero, before I added.
    14,600g / 24ft. Round Above Ground with Solar Cover and solar heater panel.
    Vinyl Liner
    Hayward Cartridge Filter (CCX 1500RE)
    2 HP Hayward Powerflo LX Pump
    Pool and solar heater get full sun, when its shinning daily!!
    Using test kit: Taylor K-2006
    Successful BBB user.
    May 2011
    Hardy, Virginia
    61
    Re: CYA Quick question.
    How are you testing your water?
    15' wide x30' long x 4.5' deep vinyl above ground, 13,500 gallons, hayward dream line sand filter, hayward power-flo lx pump 1.0 hp, lil shark cleaner
    May 2012
    55
    with the Taylor K-2006 test kit
    Vinyl Liner
    May 2011
    Hardy, Virginia
    61
    Hmmm. Did you add the stabilizer by putting it in a sock in front of your jet, or did you add it to your filter basker?
    (sorry, I just saw the test kit in your sig line
    22,553
    It could take up to a week for it to show up accurately on the test. That statement is to save you headaches in case it doesn't show up quickly and to save you reagent by not having you test it for a week. I've used the CYA from Walmart and had it show up the next day, but you can't count on that with some brands.
    May 2012
    55
    I added it in a nylon sock near my return, I am also shocking my pool atm as well. Just in the opening phase.
    Vinyl Liner
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Different water chemistry results in different CYA dissolution rates. The week is just enough time to be sure it's all dissolved. If you know your pool volume and know how much you added, you should be able to tell when it is all dissolved by the test.
    May 2012
    55
    Thanks for the quick replies. If anything, in the BBB system is tricky to me its the CYA. I will wait a whole week and test again. As I see my shocking days are almost over, as I am almost at losing 1ppm of chlorine over night. (only lost 2.5 ppm last night) We have a weekend of 90 degree weather coming up, and I hope to be enjoying the crystal clear waters!
    Vinyl Liner
    May 2011
    Hardy, Virginia
    61
    Do you have a full set of test results you can post? (And the cya was scary for me too....I didn't want to overdo it and half to exchange the water!!)
    May 2012
    55
    Since I am still shocking my pool, I have only kept up with the Chlorine, CYA, and Ph
    This AM Test results were:
    FC 18.25
    PH 7.4
    CYA 50
    Vinyl Liner
    May 2011
    Hardy, Virginia
    61
    So far so good. Keep us posted, and enjoy your pool!!!
