Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: Process of shocking
    May 2012
    new york
    27
    Process of shocking
    Hello I'm new to the forum. I have a swg pool that measures 26x46. In ground vinyl siding. I have been shocking for a week and a half and have been testing in the morning and late evening. My FC is at 20 my Cc is at 0.5. Cya is at 40. I haven't added the salt yet or turned on my salt generator yet because of the algae problem. My question is how do I get the cya level to the recommended for swg pools. Which is 70. The pool is very clear now considering what it looked like. Thank you all
    26x46 Inground Pool SWG 36,000 gallons vinyl liner with 12' cement walls. cement steps, vamiculite bottom through out pool.Bio guard SWG ms-10 system, Mini max NT Gas Heater,Pentair Cartridge Filter CCP4200, pentair whisper Flo Pump 2/.33 hp.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Process of shocking
    Welcome to the forum
    You can add the salt anytime, but test the water before you add. The water will already have some salt in it.
    Wait until you are completely done shocking before you add CYA.
    See red lines in my sig.
    You're done SLAMing when:
    22,553
    Welcome to TFP.
    BF has you covered. CYA granules are the best way but as she said, don't even think about it until you pass the OCLT.
    May 2012
    new york
    27
    Thank you very much
    May 2012
    new york
    27
    Also I'm staying in the range of cya 40 and the shock FC is 20. Now being that I have a swg my range is suppose to be cya 70 shock FC and the shock FC should be at 28. When do I go to the target FC which is 5 according to the chart.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Mrgadget14
    Best to foget about the SWG until you meet the three criteria to be done shocking (red lines in my sig). After that, you can let the FC drop down to maintenance level (5 ish), increase CYA to about 70, and dial in the SWG.
    May 2012
    new york
    27
    Thank you butterfly. Your awesome
    May 2012
    new york
    27
    At 825 am i tested the water and my fc was 21 my cc was .5 My ta was 80 my cya was 40 ok now i just tested the water @820pm and my fc was 3.5 my cc was .5 my ta was 80 my cya is 30.. now what should i do..
    Apr 2011
    Lynchburg VA
    393
    I would retest the CYA, it should not have dropped from 40 to 30 like that.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    38,475
    I would forget about the CYA test ... you know it is 30-40 and only accurate to +/- 10 anyway.
    Just keep adding chlorine to stay above the shock level for a CYA of 40ppm.
    May 2012
    new york
    27
    Ok will do. Lets see what 2morrow brings
    Butterfly's Avatar
    South Carolina
    10,045
    What was the pH level before you started shocking?
    You do not need to retest anything except FC & CC during shocking.
    However, if the FC falls below 10, retest and pH and make sure it is in the mid 7's.
    May 2012
    new york
    27
    845 am thursday FC stood at 15.5. Cc .5 and the pool is crystal clear. So what should be my next move. Check it again in the afternoon. See where the levels r. Ohh and also the ph was between 7.2&7.5
    I'm going through the same thing you are right now. It seems it will never end. Just when I think i've got it beat my CC bumps up to 1
    18' x 36' saltwater inground vinyl pool
    May 2012
    new york
    27
    Yeah it sucks but I'm really learning what I should have learned 7 yrs ago when I got this pool. It s becoming annoying and fun at the same time thank god for people on this site that know what there talking about. The people in most pool places are clueless. Keep working on it we will get it right.
    Butterfly's Avatar
    South Carolina
    10,045
    okay, looks like you have 2 out of the 3 requirements to be done shocking.
    You need to pass the OCLT - described here: pool-school/overnight_fc_test
    May 2012
    new york
    27
    K. Thanks.
    May 2012
    new york
    27
    Hello. Thurs @730 pm my FC was 13.5 cc .5 ph 7.2. This morning fri @ 1:30 am when I got home from work FC 14 cc 0.5 ph 7.2. Now it down poured for a while. @9:25 am this Friday morning FC 12.5 cc 0.5 ph 7.2 TA 80 CH 280 and the cya was 40. I'm thinking I'm in the clear to boost up the cya and start adding my salt and turning on the swg. Any suggestions.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    What about part three of the shocking process - is the water clear? If it looks good, go for it.
  20. Back To Top    #20
    May 2012
    new york
    27
    The water is crystal clear. Thats what im doing the 3 shock test. I think im there unless someone tells me different.
