Thread: What FC level is too high to swim in while shocking
    May 2012
    tn
    34
    I am in the process of shocking and have been for past week. Cya 38, FC 19 this morn and Im trying to keep it around there per the cya/fc chart. My question is my kids are dying to swim (pool is almost clear but not quite) but I havent let them yet.. I am wondering at what level is it too high for them to swim. Is it ok for them to swim for a little while or not a good idea. I dont wanna harm them or the shocking process either. Thanks for any help
    16x32, 20k gal, IG, vinyl, hayward sand filter model S244T 24in, 1.5hp
    Butterfly's Avatar
    South Carolina
    10,045
    Re: What FC level is too high to swim in while shocking
    Assuming CC is .5 or less, you can clearly see kids under water and FC is at or below normal shock level for the CYA level, it's okay.
    however, it is best to just keep everyone out until you are done shocking
    You're done SLAMing when:
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,082
    Easy button answer...they'll be fine. Maybe a quick rinse with a hose afterwards.
    Long answer.....makes for a good read.
    http://www.poolsolutions.com/gd/best-gu ... chart.html
    May 2012
    tn
    34
    CC is 0. Thanks guys This forum is absolutely a lifesaver (and wallet saver)
