Thread: What are symptons of high CH?
    What are the symptoms of very high CH? If you didn't have a test kit, how does it present itself?
    24k gallon inground with 500 gallon spa, 580sqft Jandy cartridge filter, Jandy ePump 2HP variable speed pump, Jandy 1400 SWG AquaCal Heat Pump, Diamondbrite Aqua Quartz plaster
    Nov 2010
    Calera, Al
    271
    Re: What are symptons of high CH?
    Quote Originally Posted by gsxrken
    Calcium scale and a calcium ring around the waterline.
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    You'll also have water spots on glasses out of the dishwasher, white crust on faucets and showerheads, maybe a ring around your toilet bowl, lots of white film on shower tiles. These all indicate hard water, and if that's what you're using to fill the pool, your pool will have high CH.
