Thread: Out Of Round PVC Advice
    I need some advice. I had to disconnect a leaky, very old heater, and needed to do some replumbing. Unfortunately, I have a pool return line that is 1 1/2 inch PVC that is to oval to fit a coupling over.
    I would definitely cut and replace if I could. There is about 10" sticking out of the ground, and all of it is oval. The rest goes about 50 ft under dirt, mulch, and concrete to the pool jets.
    I need to connect to it somehow.
    I have a few ideas, what do you think would be the best option?
    1. C-Clamp it until it rounds (And hopefully not break it, since I don't have much length to cut back off)
    2. C-Clamp is more gently, but assist with a heat gun or hair dryer (Would this affect the bond?)
    3. Mission clamp. The return line is after the filter, and about 8 feet above the pool return jets, so it is technically "low pressure"
    4. Your suggestion here!
    Steve
    _____________________
    15K IG Fiberglass
    IC40 + Easytouch + Superflow 1 HP 2 speed
    Sherlok 120, MaxETherm 200 HD Heater, Southeast Michigan
    Re: Out Of Round PVC Advice
    Welcome to TFP!
    I would dig down a ways around where the pipe goes into the ground and see if it becomes round underground anywhere near there.
    You can reshape PVC pipe with a heat gun/hair dryer but it is very tricky to get it to go back to round. A mission clamp would work for a while, but would not last nearly as long as everything else will.
