Thread: Filter does not seem to be filtering
    We replaced the Zeobriite in our sand filter. The system has been running for days and the water is still cloudy. We can't see the bottom-12'x25' patio pool. The water test from our pool supply store is all within normal ranges. The filter doesn't seem to be taking anything out of the water.Backwashing doesn't seem too dirty. Lots of pressure through the returns but appears cloudy. Help!
    14k gallon oval agp, sand filter, 1hp pump, BBB method, K-2006 Test Kit
    Roanoke, VA
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Filter does not seem to be filtering
    Welcome to the forum
    Pool store 'normal' water test results are very often not what we might consider 'normal'.
    Most cloudy water issues are water chemistry issues.
    Post a full set of test results and we can get started helping.
    You're done SLAMing when:
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Did you thoroughly backwash the filter after adding the Zeobrite?
    Mar 2012
    Amarillo, Texas
    341
    Zeobrite is really dirty at first. Did you backwash and rinse? I always forget the rinsing part!
    18'x48" AG
    Pentair 1 1/2 HP Dynamo Pump
    Sand Dollar Sand Filter w/ Zeobrite
    Lil Shark Vacuum System
    Hard Plumbed
