Results 1 to 15 of 15
Thread: Would this be a good used pool to buy?
    nelson411's Avatar
    Aug 2011
    Northern California
    165
    Hi all,
    I've gotten so many wonderful suggestions from everyone here on what kind of pool to get. Most have suggested getting a used pool. So I'm scouring CL when I can, and I found a possible pool to look at.
    I wanted to hear any feedback from you all before I drive out (an hour) to see it.
    Here is the Ad from CL:
    I need to sell our 12x24 foot Doughboy pool. This is an awesome pool, steel construction (built to last that is, not like the flimsy ones at Costco) I purchased it (for ALOT more than I am selling it for now), and disassembled it from our friends back yard, 3 years ago. (They had set it up, and used it for 3 years previously) ...
    This pool comes with a liner, which has been stored in our garage, (although I have to admit, it has been rolled up, and I see a hole. I asked a dealer about it, and he said there is a patching kit you can purchase)
    It also has the pump, filter, and everything needed, including detailed Pool assembly and installation instructions! And, like I said, i'ts disassembled and ready to load in your truck!
    $500
    What kind of questions should I ask before seeing it?
    I'm concerned about the pool being stored for so long, and wonder how that might affect it.
    I asked about the name of the pool, and she didn't know, but knew it was a doughboy.
    Any feedback would be great!
    Cheers,
    Liz
    (so glad the grading is over, and now I can spend all of my time obsessing about pools while the kids are still in school!)
    Northern California Inground pool 14' by 30'
    Diamond Brite Quartz Medium Grey Plaster - Islands Sapphire Breeze Tile Border
    Jules Bright Cobalt Blue Blend Tile Bench fountain sheer waterfall descent
    Pentair Intelliflo Variable Speed Pump - Pentair CLean & CLear PLus Cartridge Filter - Kreepy Krauly Legend - mTF-100 Test Kit ™ - Swimmers: Twins (Boy/Girl) 16 yrs old
    Apr 2011
    Lynchburg VA
    393
    Re: Would this be a good used pool to buy?
    The only thing I can tell you about Doughboy pools is that I installed one at my parents house in 1989 and it's still there. I would be prepared to replace the liner. The one I installed was a 12x24 as well and required some pretty serious bracing on the side walls. I had to dig out areas along the sides of the pool to bury cinder blocks that supported and braced the side wall supports.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Make sure all the pieces are there. Be prepared to do some rust removal/conversion. You will have to buy a new liner. Try and layout the pool in your backyard with a hose to help visualize what it will look/feel like 12X24 is not a real large pool (LOL I only have an 18') and is almost as much work to setup as a larger pool. Try http://www.searchtempest.com to look on craigslist in a larger area!
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    If the pool is in good condition, no rust through, no missing parts it should be a good deal. If you go out to look at it, let the owner know in advance that you will want to unroll the pool to look at the side walls. Check the walls for rust through and long horizontal creases or signs of crumpling and pass on the pool if it has them. Use the installation guide to check that the parts are all there. Also see if there is a Doughboy dealer convenient to you in case you do need to get any replacement parts.
    You will need a new liner. I wouldn't even try to install the old one. It has been out of the water a long time so it probably has shrunk and become brittle, plus you would have a heck of a time trying to get the skimmer and return holes to line up correctly.
    Also make sure you have enough space in your yard. For a 12x24 pool you will need 14x26 space that does not encroach on easements that you can level without too much difficulty. Marking the layout with spray paint or flour will help you see if you will be happy with a pool that size and if it will fit where you want in the yard.
    Love TFP? Become a
    TFP Supporter!
    nelson411's Avatar
    Aug 2011
    Northern California
    165
    Hi BadOleRoss ,
    Good to know about the Doughboys! I've heard good things about the new ones, but not sure on how they hold up.
    Siince 1989?
    Liz
    nelson411's Avatar
    Aug 2011
    Northern California
    165
    mcoonan,
    Thanks for the tips!
    I will check out that website.
    I figured we would need a new liner. Would I have to buy a doughboy liner? When I was looking at the dealer, they were big on that idea. Probably a sales thing?
    mcconan: 12X24 is not a real large pool (LOL I only have an 18') and is almost as much work to setup as a larger pool.
    I wish we could go larger, but that is the biggest pool that will fit into our dinky backyard.
    I know what you mean about the amount of work. Our pools over the past years have grown in size, like a goldfish grows to the size of it's bowl. We started with a 5 foot wide intex, then a 9 foot, then last year a 14 foot!
    Off to search that website.
    Liz
    nelson411's Avatar
    Aug 2011
    Northern California
    165
    Hi zea3!
    Great tips! I never would have thought of what to look for. This forum is the best!
    They say they have the guide, so that is good news. However, the dealer is kind of snooty, for some reason. I saw them give someone a difficult time for getting parts for a pool they didn't purchase from them. I can handle them, but will have to use my swat team negotiating tactics!
    Good point. I'll check with the city guidelines. We have the space, but I don't know what is code for our little town.
    Like the flour idea! We have a lot since neither of us do much baking! Rather be baking in the sun by our new pool!
    Looks like we will need at least good hour to look over the pool. What tools should I bring along, if any.
    thanks again!
    Liz
    Mar 2012
    NC
    138
    Is a crease in a wall a deal killer if there is no rust? Just asking because shadebuilder (who has been referenced here before as having good info so I hope this is not against the rules), has said you can bang them out and the pool will be fine. Just asking of course and still learning.
    33' Seaspray Aegean II - 6' Deep End
    28K Gallons
    2" Hard Pipe Plumbing
    Hayward S244T 300 lb. Sand Filter
    1 HP - 2 speed - Powerflo Matrix Pump
    22,544
    It could be. Depends on how bad it is. The way the walls are constructed if it's a bad crease you can never get it out and it may have structural implications. If it's a slight crease it'll be fine.
    I purchased a used pool a few years back. It was twice as old as the one you're looking at. It was a Lomart brand pool, which I'm told is just a doughboy in disguise. Actual parts were hard to come by, probably because of it's age, but I made due and did some structural fixin' up as I couldn't get parts. My trials and tribulations were recorded with lots of pics. buying-a-used-agp-t16890.html You'll need some time to go through all 275 posts though.
    Like everyone else has said, chuck the liner and get a new one. I also found that the installation manual had parts listed that weren't even used, and didn't even have an actual place for them! So buying a pool that's already torn down may or may not match what's in the installation manual. That was my experience though, your mileage may vary, and the manuals may have gotten better since mine was printed. At the very least make sure you have the same amounts of verticals as you do top and bottom plates and top caps. Those could be hard to come by... maybe not since it's a newer pool though.
    Whatever you do, have fun with it, and post lots of pics!!
    Rob B
    My $100 pool finally died after 6 years.
    Totally got our monies worth!
    Butterfly made me do it...
    nelson411's Avatar
    Aug 2011
    Northern California
    165
    Hi Kias,
    What a great job you did with pool!! I just had to go through and see the photos! What a beautiful place, beautiful pool, and beautiful kids!
    I don't think me and my DH had the know-it-all or the energy to do what you did! Amazing!
    I found out that someone else got the pool I was looking at. So back to square one.
    Thanks for your help!
    Liz
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by nelson411
    Thats a bummer Hopefully another good one will show up soon!
    nelson411's Avatar
    Aug 2011
    Northern California
    165
    Thanks!
    I hope so. It was the perfect size. Back to CL!
    Cheers,
    Liz
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Sometimes it can be the attitude that you bring into the store that can cause the issue. I watched a parts person at the pool store give a customer attitude after the customer tore into the parts person for something that he could not have done anything about (defective new pump motor). That parts person then turned to me and was super helpful, and even lost a sale to me for a large patch kit and suggested that I use shower pan liner and glue to make up my inlet and skimmer surrounds. Turned out alot cheaper and stronger.
    Aquabot Pool Rover
    Apr 2011
    Lynchburg VA
    393
    Hi BadOleRoss ,
    Siince 1989?
    Liz
    Yep, 1989!
    Pool School
    Pool Calculator
    Test Kits
