Thread: Dead Critter in skimmer - shock?
    May 2012
    Jackson, TN
    24
    Found a small mole in my skimmer this evening. I've always been advised to "triple shock" in this case by the pool store.
    Do I need to shock?
    Is there shock method other than raising the FC sky high? Is traditional non-chlorinated shock/oxidizer OK?
    In-ground, vinyl pool, 26,000 gals
    Hayward Sand Filter, Aquarite SWG, Hayward Ecostar Pump
    Re: Dead Critter in skimmer - shock?
    I wouldn't get too worked up about it if your chlorine level is where it should be and the mole had not been in there more than 24 hours or so. If you're worried you can shock using the Pool School instructions.
    16x32 Oval In-ground Vinyl, ~17,000 gallons, Hayward 1hp Superpump, Hayward S245T Sand Filter
    Worn out sand? sand-filter-expert-help-t30049.html
    Drain the easy way: cyanuric-acid-blues-draining-pool-t43843.html
    http://tftestkits.net/splash-page.html , pool-school/chlorine_cya_chart_shock , pool-school/shocking_your_pool
    Apr 2011
    Lynchburg VA
    393
    IF your FC and CC are within range I would not worry about shocking. I find moles, frogs and other small critters in my skimmer from time to time and unless I have neglected to check the skimmer for days it has not been an issue. It's when they sit in there for days that I pay the price and have to shock.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    If it makes you feel better raise the pool to shock level overnight, mustard shock level if you are really anxious. "Triple shock level" is crazy. Usually you only need to shock if serious decomposition has set in before discovery.
    Love TFP? Become a
    TFP Supporter!
    Jan 2011
    Huntsville, AL
    67
    We found a small mouse last week in our pool. I did not shock and swam 2 days later. I am still here to talk about it!
    16 x 32 inground with Tara Liner, 1 skimmer, 3 returns,
    1HP Hayward Super Pump
    Hayward Sand Filter
    Polaris 280 w booster pump
    Hayward SWG & Aqua Plus
    k-2006 Test Kit
    Oct 2011
    Charlotte, NC
    120
    If you're worried about a mole in your pool being dangerous be sure to never swim in any lake or ocean again.
    8000 gallon outdoor inground vinyl. Sand filter, Hayward 1HP.
