Thread: Pool collapsed in rain
    Mar 2008
    Mansfield, Tx
    After 6 weeks of waiting for permits they start on the pool. Day 1 it's excavated, Day 2 they lay the rebar, Day 3 it rains.
    The sides do a landslide act, the PB says don't worry, this happens and he will make it as good as new. Any expierience or words of encouragement?, on Flickr">, on Flickr">
    16K Gunite, Spa w/ Waterfall
    Beadcrete Plaster. (3) Shear Decents
    Jandy 60 Sq ft DE Filter
    (2) Jandy Stealth 2.0 HP Pumps
    AquaPure SWG w/ PDA
    (5) Returns, (2) Floor Drains, (1) Skimmer
    LXi Heater, Letro Platium Cleaner w/ Booster Pump
    These things happen sometimes. As long as you have a good builder they will take care of whatever work needs to be redone. They only had two days of work into it, so worst case they need to do those two days over.
    reef n ale's Avatar
    Mar 2008
    Mushroom Capital of the World
    I'm no expert, but I think you'll be ok. It looks like your PB did a really nice job on staking it out and the steel work, so they should be able to set it straight.
    And six weeks for permits??? Wow.. if you can make it through that, you can make it through anything!!!
    25000 Gals, Intellichlor IC40 SWG , Intelliflo 4X160, Pentair Cartridge Filter, Easy Touch 8, Polaris 280
    My adventure: my-new-pool-build-t4534.html
    Rocklin, Ca
    I think the only potential issue would be when they backfill after gunite. Make sure they compact this soil well before concrete.
    11000 Gals, Intelliflo, Sta-Rite Cartridge, Polaris 360
    Pool I built in my old house: my-new-pool-build-t4534.html
