Results 1 to 12 of 12
Thread: Replacing Hayward 1 1/2hp super pump
    Need to replace 1.5 hp Hayward super pump.
    A few details;
    26k gal vinyl in ground
    Saltwater
    2 skimmers
    2 drains
    3 returns
    1.5" PVC pipe
    All pipe home run back to valves in pump area
    Hayward Gas heater
    Chlorinator
    Polaris 9300 cleaner
    NO other accessories
    I initially planned to replace with variable speed or two speed ( Hayward or Pentair) but after reading the forum l am wondering if a 2 speed replacement would be better.
    Thanks
    Re: Replacing Hayward 1 1/2hp super pump
    Welcome to TFP!
    If your electric rate is below $0.20/kwn then a two speed pump is a more economical choice.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Why do you need to replace the SuperPump?
    Quote Originally Posted by Isaac-1
    I replaced the bearings about a year ago. When I opened the pool this year they apparently had gone south again. In looking at the motor, it has corrosion on the bottom side of the frame to the point that metal has started to "flake"away. It had already started to do this when I replaced the bearings. I think due to this corrosion the front flange isn't seating properly. Bottom line unless I can get a new frame I think it's toast, plus Id like to get something more energy efficient. Thanks for the question.
    May 2009
    Youngsville NC
    395
    You could simply replace the motor on the SuperPump with a new 2 speed , and it should save you money over a completely new pump. Just be sure to get a seal kit as well.
    http://www.electricmotorwarehouse.com/56Jframe.htm has some you can look at - look at B969 (120V) or STS1152R (240V) as a 2 speed replacement
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    Thanks for the motor suggestion, just got it installed today. At this point I only connected the high speed. How do you normally control the low and high speed. Originally I had installed a wireless relay unit to turn it on off, are there relays specifically made for 2 speed pumps?
    They do make versions of the kind of relay you have that work with two speed pumps. One simpler approach is to use a manual switch to pick between high and low speed. In most cases you leave it on low all of the time, and only turn on high in special situations (like backwashing, vacuuming, etc).
    My 3/4 superpump is 7 years old and it's getting loud. The sound is kinda the same as it's always been, but 4-5 times louder. Jets shoot out fine, pressure is good. I'm handy and can fix things. Is this worth fixing if I have a bearing puller, etc?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    In my personal experience by the time the bearings go the rest of the motor is not far behind.
    Ike
    Yes, it's about 8 years old. Really?
    http://www.youtube.com/watch?v=_M_2Kpuq_xY
    WestSidePool's Avatar
    Cincinnati, OH
    424
    My 3 year old Superpump motor did the same thing 2 summers ago (due to water). Picked up some new sealed bearings at a local automotive store and replaced them. Thing ran and sounded great.
    For the cost of the bearings (less then $15) might be worth a try just to see.
    I had to replace my motor this season due to the above water leak that I could'nt get sealed. Motor was rusted and corroded inside. So take your motor age, time invested in replacing the bearings and figure out if it's worth fixing or worth upgrading to a more efficient unit.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
    I just purchased 2 new bearings, shaft seal and a bearing puller from www.wetheadpumprepair.com
    Their customer service is awesome and they stand behind what they sell. I checked into this, and wanted to be sure I was getting quality bearings and parts, and their reputation is great. Will report back.
