Results 1 to 11 of 11
Thread: Pool sample
    May 2012
    Danville, IN
    21
    Pool sample
    I've done some searching but only found that pool sample should be taken 12-18" under the surface. My question is where should it be taken? Should it also be taken in the same place each time? Thanks!
    25K gal IG Vinyl Ell shaped pool, Pentair SuperFlo 1.5HP single speed pump,
    Pentair SandDollar sand filter (Zeobrite), Pentai Intellichlor IC40 Chlorine Generator
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Pool sample
    I think everyone has a spot that's easiest to reach for whatever reason - planters, decking, narrow walkways - so they tend to use the same spot every time. As long as it has decent circulation it should be fine.
    May 2012
    Danville, IN
    21
    Re: Pool sample
    What's the best way to tell if a spot has good circulation?
    Richard320's Avatar
    Jan 2010
    19,037
    Re: Pool sample
    Quote Originally Posted by dk5jmiller
    You see ripples on the surface. Or you know it's downstream from a return if the return is pointed down.
    22,551
    Re: Pool sample
    You could take a little food coloring and squirt it in the location and if it's quickly carried away you'll be able to see how good the circulation is in that particular spot.
    May 2012
    Danville, IN
    21
    Re: Pool sample
    Thanks! Great idea! I really appreciate your help. I've been in shock mode for a couple of days now. CC has never been more than 1, mostly 0.5 - but not able to hold OCLT yet. If my water is not sparkling though, I don't know what sparkling is... I usually get a lot of junk blown in my pool, so that may also be playing an effect. Have you seen pools where you simply cannot ever meet the OCLT?
    22,551
    Re: Pool sample
    Never. It's designed so that every pool can pass it. If you can't pass it there's something going on that shouldn't be going on and it needs to be corrected.
    May 2012
    Danville, IN
    21
    Re: Pool sample
    Ok, thanks. Just checking... I was indoctrinated in the pool store method of pool care and have only recently found this forum. I'm having to relearn some things, so I'm sure I'm just getting a little impatient. This is my first attempt at shocking, so I'm a little unsure of myself. Having my TF-100 sure has saved a lot of trips (and unnecessary purchases) from the pool shop.
    May 2012
    Danville, IN
    21
    Re: Pool sample
    Woohoo!! Water is crystal clear, CC is less than 0.5, and passed the OCLT last night. Since normal testing only tests to about 0.5ppm, I'm assuming that's why you meet the 3 criteria?
    How often should I expect to shock the pool? The pool store recommends shocking weekly, but they don't shock properly anyway. With the SWG, I was finding I could get by shocking every other week or so. Using the Pool School method, what might I expect for shocking intervals?
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Pool sample
    Correctly shocking, as practiced here, is used to solve a problem in your pool.
    As long as you maintain a proper chlorine level and water chemistry, you should never have to shock.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pool sample
    Smykowski is right on. This method of pool maintenance only uses the shocking process to fix problems and requires maintaining (generally) proper FC levels for normal operation, which then prevents organics from growing in the pool. If you end up needing to shock regularly, you are not following some portion of the method correctly.
