Results 1 to 14 of 14
Thread: Algae Wars - Day 10
    May 2012
    The American Sector
    8
    Algae Wars - Day 10
    1st - Thx for the site. I really appreciate the knowledge that is shared.
    As the title says - I'm into day 10 of Algae Wars.
    7000 gallon spool - in Phoenix.
    Pebble Tech.
    Cartridge Filter.
    2 speed pump. Running on high 24/7 except for a few hours down time when I found a leak in the plumbing.
    Testing with Taylor 2006.
    When I started:
    Ph was 7.3.
    CYA was 70.
    I've been targeting FC of 30. On weekends I can stay on top of it. During the week I test morning and evening. My wife tests once midday. Given the sun, we lose a lot of FC during the day. My overnight test last night dropped 2. During the day it drops to 22 at midday and again by the time I test in the evening. I brush twice a day.
    The water is clear. No sign of algae. My problem was mostly on the walls. The water has always been relatively clear.
    I didn't realize the effects of high CYA until reading here. I was over 150 before I did a drain. Not backwashing the cartridge filter just keeps the number ever increasing (lesson learned).
    Any advice from here would be appreciated?
    Are there any properites that I should be testing other than FC right now?
    TIA!!
    7000 gallon IG Spool
    PebbleTech
    In-Floor Cleaning system
    Waterfall
    2 HP Whisperflo 2-speed pump for filter, cleaning system, and therapies.
    1 HP Whisperflo pump for Waterfall
    Pentair Clean & Clear Plus 420 Cartridge Filter
    Taylor 2006 test kit
    30,395
    Re: Algae Wars - Day 10
    Actually, you seem to have a really good grasp of the shock process and you are doing everything correctly, I think.
    What will be your ending CYA and how will you chlorinate your pool once the shock process is complete (you are close )
    May 2012
    The American Sector
    8
    I assume my ending CYA will still be CYA. Or was that a trick question? lol
    I've made the switch to liquid chlorine. No more tabs or powdered shock.
    PebbleTech
    Waterfall
    22,537
    I think what Dave meant was what CYA are you going to try to reach once your done shocking. Are you going to just leave it where it is, or are you going to try to lower it some more?
    May 2012
    The American Sector
    8
    Got it.
    Well, I already rented the pump and did the drain before the heat came. I pulled out enough to get to 50 based on a CYA reading from the pool store.
    I was aiming for 50, but got to 70. I don't believe the pool store measurement was accurate. (This was before I bought the Taylor test kit - another lesson learned).
    So I'll continue to pump out some water a couple of inches at a time until I get down to 50ish.
    My most efficient water dumpers are my labs. lol
    PebbleTech
    Waterfall
    May 2012
    The American Sector
    8
    Still at it.
    I'm back to losing 6 or more PPM every night and the daytime loss has increased as well.
    Not sure the cause, but here are a few things that have changed.
    1) We had a front move through with lots of wind Thur/Fri.
    2 ) Friday, I decided to clean the filters. Got that done. Noticed the o-ring that seals the filter halves was a little stretched but it seemed to go back together. Started up the pump. No leaks. Came back about an hour later and about 18 inches of water were drained out of the pool. The seal had let go big time. Found a new o-ring on Saturday afternoon and restarted the pump and testing/shocking.
    3) My waterfall has an a separate line for an attachment that I never used. I switched the valve over to run some water through that line.
    4) Started using a new bottle of DPD Powder. It looks a little more coarse than the 1st bottle that came with the kit.
    So any thoughts? I've been at this for 2 weeks. I never had really green water. The pool is open year round. But was getting algae on the walls.
    Given the partial drain and refill, can I retest the CYA at these high FC levels?
    Thx again!!
    PebbleTech
    Waterfall
    Aug 2010
    Dallas, TX
    4,052
    If you are still losing 6ppm overnight, you haven't finished shocking. Algae on the walls tells you too.
    May 2012
    The American Sector
    8
    Quote Originally Posted by RobbieH
    Sorry, I should have been more clear. The walls and water are clear. The algae on the walls was my starting point.
    PebbleTech
    Waterfall
    Aug 2010
    Dallas, TX
    4,052
    Oh, by the way, I don't believe high FC levels will affect your CYA test, as long as it's the turbidity test and not strips.
    May 2012
    The American Sector
    8
    Thx, I guess I drained more than I thought. I'm now at a CYA of 43ish.
    PebbleTech
    Waterfall
    30,395
    Almost a perfect place to start...you can always add...very hard to subtract.
    May 2012
    The American Sector
    8
    I ceased hostilities on Thursday. I've been working to rebalance the pool over the weekend. Things look terrific. Can't thank the folks here enough!!
    FC 5
    CC 0
    pH 7.5
    TA 80
    Ch 300
    CYA 43ish
    PebbleTech
    Waterfall
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Quote Originally Posted by drfous
    So stick around and answer some questions. Someone who's done it can better explain things to someone who needs to be convinced and instructed.
    May 2012
    The American Sector
    8
    Quote Originally Posted by Richard320
    That and I'm not done with questions.
    My next task is to get rid of the bath ring I've got from 8 years of pucks and "shock".
    lol
    PebbleTech
    Waterfall
