Thread: Best way to clean and protect vinyl safety cover
    I'm new to the forum, happy to be able to get great opinions and advice.
    I have an 18 x 36 inground vinyl pool with an automatic safety cover. The pool is 7 years old and we have just replaced the cover. With the previous cover, we would brush and clean it twice a year with a mild powder detergent (Dreft) and then hose it off with a pressure washer.
    My question is, now that I have a new vinyl cover, what do you use not only to clean the cover, but hopefully protect it to live a long life? Armour-all would be great, but that would cost a huge amount of money for a piece of vinyl this big. Please offer suggestions.
    Intex AG, 7,610 Gal, cartridge filter
    Re: Best way to clean and protect vinyl safety cover
    I have a 30 inch foam squeegee that i use to clean the cover. Home Depot
    First I add water on the cover , let hose run about 5 minutes, then I add about 1\2 to 1 gallon bleach to the water.
    I use the squeegee to brush and clean the cover, then I place my cover pump onto the cover and run the chlorinated water into the pool through the skimmer
    Use the squeegee to push the water to the pump and remove all the water from the cover.
    I rinse with plain water and squeegee dry to finish
    The cover will be spotless, and dry instantly in the sun.
    Here, I make an assumption. If chlorine in the pool dissipates due to the sunlight, the small amount left on the cover will be gone within 1/2 hour at most. thus no potential damage to the cover.
    My cover always looks clean, never any brush marks!
    I also use the same squeegee to clean my vinyl pool, I never use a brush. I used my polaris the first year I had the pool and have not used it since.
    Pool is 7 years old, in Illinois, Coverstar cover still looks and works great. Just replaced the ropes and guides this year for the first time.
    Cover star sells a cover cleaner-protectant, I have no experience with it.
    16 x 36 inground rectangle 18000 gal
    Vinyl liner
    Coverstar automatic cover
    CIRCUpool SWG 2012
    16 x 36 Inground 18000 gal
    Vinyl liner
    Coverstar Automatic cover
    Sta-Rite 1 H.P dura-glas
    Purex 2400 DE Filter
    RayPak 266000 BTU heater
    CircuPool RJ30 SWG
