Results 1 to 7 of 7
Thread: Aerating Question
    May 2012
    York Pennsylvania
    45
    Aerating Question
    Hi all, I have a curiosity question lol.
    I am currently lowering my TA and something crossed my mind. So I aerate to re-increase my PH and eventually I will get both PH and TA in their happy zone. So here is the question....As my kids splash and play (aerating the pool) this means my PH will always be on the rise?
    Dave S
    24x52" Round AGP
    Hayward S244T 300 pound sand 1 HP matrix pump
    Taylor K-2005 Test kit with the K-1515-A FAS-DPD added on.
    No one is useless, you can always serve as a bad example!
    Re: Aerating Question
    Pretty much, yes.
    How much pH rise occurs depends on several factors, such as the TA, pH, water temperature and amount of aeration.
    Support the site
    May 2012
    York Pennsylvania
    45
    Thanks. I guess I will learn how to adjust for that as I go. Right now water is 75 degrees and in 4 hours of aerating it went from 6.8 to 7.3. I was shocked it worked so well.
    Dave S
    24x52" Round AGP
    Once you get your TA down to a reasonable level the PH will be fairly stable. The rate at which PH increases goes way down as TA gets lower.
    May 2012
    York Pennsylvania
    45
    Oh. TA 120 and coming down. Aeration looks like a rooster tail off a jet boat
    Dave S
    24x52" Round AGP
    May 2012
    York Pennsylvania
    45
    BTW that acid is nasty stuff. The moment I opened it I went for the chem gloves and eye protection, smokes like a chimney lol And I didn't ready the warning until I got home with it, and my 4 cases of Bleach all in the same part of the car lol.. DO NOT STORE OR MIX WITH BLEACH. OK Ill shut up now You all have me excited I get to play chemist every day hahah
    Dave S
    24x52" Round AGP
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    My TA is at 110, and pH is nearly rock steady. I can get away with only a small amount of dry acid once every 7-10 days or so now, even with heavy kid load splashing and stirring things up. So, you're pretty close to the "sweet spot" ime.
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
