Thread: 2 Speed Pump Strategy
    Just installed 1.5 Whisperflo 2 speed pump. Current approach is 24 hr operation with 20 hrs low rpm and 4 hrs high rpm after chlorine add. Any better pump operational patterns based?
    Kenbob
    inground, 23,000 gallons, vinyl liner, sand filter, 2 speed Whisperflo 1.5 HP, gas heater
    Re: 2 Speed Pump Strategy
    As long as your skimmers work well at low speed, there is no need to use high speed except in special situations (vacuuming, backwashing, cleaning up algae, etc). Also, you can probably have 12 hours a day or low, or less, and still be totally fine (though the only way to be sure is to try it).
    Jun 2007
    New Jersey
    653
    I just put an A.O. Smith 2-speed 1.0 hp (full-rated) in my WhisperFlo on a 28k gal. pool. I've been playing with the run times for three weeks now. Currently running just low for 12 hours in two blocks. It's keeping up fine despite heavy spring pollen/tree crud and lots of rain. I expect to cut it back even more later in the season. I have a DE filter and my clarity test is the beam from my pool light. If I can barely see the beam, all is good. Once the beam is well-defined and I can see the particles, then it's time to up the run time.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
