Thread: Newbie needs advice!!
    May 2011
    Hardy, Virginia
    61
    I have been having a problem with cloudy water- turns out my filter wasn't working properly. I have been able to clear the water a lot today by shocking and running the filter. Water took on a weird color last night and i was afraid it was algae. My cc is zero though. My question is...can vacuuming cause the water to cloud up again?
    Here's my most recent results:
    Fc 23
    Cc 0
    Ph 7.6
    Cya 45
    Last night's oclt was less than 1 ppm
    15' wide x30' long x 4.5' deep vinyl above ground, 13,500 gallons, hayward dream line sand filter, hayward power-flo lx pump 1.0 hp, lil shark cleaner
    38,271
    Re: Newbie needs advice!!
    Vacuuming could stir up some of the fine debris and make the pool cloudy ... or some of the fine stuff could be making it through your filter.
    Sand filters can sometimes take a while to clear up the pool ... keep at the shocking for a couple more days to be sure.
    Butterfly's Avatar
    South Carolina
    10,045
    Do you have TA and CH test #'s? If you mention cloudy, we wanna know these, too
    You're done SLAMing when:
    May 2011
    Hardy, Virginia
    61
    Sure. TA is 150 (I'm adding dry acid to get it down) and the CH is 40
